  • Guests: 15
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
ne555 damaged controlling push pull oscillator
Yunus
Tue Oct 10 2017, 12:55PM Print
Yunus Registered Member #61794 Joined: Sun Sept 17 2017, 04:13AM
Hi, i make push pull oscilator stepping down 12V to 1V 15A.
Everything is working fine, the output can heating the nichrome tip perfectly.
Then I added PWM (pulse width modulation) circuit to control the power output of the oscillator.
Turning on & off the oscillator quickly, but the frequency far lower than the oscillator,
by enabling & disabling the mosfet's gate.
Everything is working as intented, the PWM can dim the power output.
BUT after 10-20 minutes, the 555 timer died.
I replace the chip with the new one but still die again,
even if i added 9v zener & 68 ohm resistor as a protector.
Do you know what the causing ne555 destroyed?
Any idea to protect the chip?
10
1507639974 61794 FT0 Img 20171010 194834
hen918
Tue Oct 10 2017, 01:42PM
There is probably noise getting into the 12v Vcc of the 555 from the high frequency mazzilli driver. I would suggest putting a low-pass LC filter (or even just some decoupling capacitors as near as possible to the 555 Vcc).
You might have problems turning the PWM BJT off properly. I would connect the 200ohm resistors (R4 & R3) directly to V++, then put a couple of diodes on the 'FET gates (anodes to the gates, cathodes joined together), you can then use a NPN BJT or N-channel MOSFET to ground the gates directly to switch them off. This, I would have thought, should be more reliable
Yunus
Tue Oct 10 2017, 02:11PM
10 1
Is that correct?
But, disabling the oscillator for long time by grounding will causing two 200 ohm resistor overheated together, comsumpting power 2x 0.72 watt.
My approach is likely better, unplug the 200 ohm resistor from the vcc.
I think using my or your apporach still causing 555 chip burned again.
the chip was protected by 9 v zener, 68 ohm resistor (reducing 3v from the vcc), and 2n2907 transistor (not directly switch the mosfet).
the transistor still healty but the chip still burned even if having multiple protection.
the choke is about 4-5 mH, it should smoothened the current nicely.
Using capacitor? 100 uF is enough?
hen918
Tue Oct 10 2017, 02:35PM
Yes that's the circuit. I use 470 ohm resistors, so the power dissipation is a lot lower. The problem with your design, is it only leaves the 10k resistors to keep the gates of the MOSFETs at ground. My feeling is that they could be left for a few cycles with a few volts on them; enough to cause them to overheat. Try simulating our designs (mine's based off of Uzzors2k's capacitor charger) and see what the voltages are doing. Or if you have a scope, take some oscillograms.
Edit: and on the capacitor front you want a lower value ceramic one. 100nF should do. remember it's only for high frequency noise so a lower internal resistance is more important than value.
Yunus
Tue Oct 10 2017, 03:19PM
I don't have an oscillope cry
It is very expensive to me.
Is there any bluetooth module to turn my android to be an oscillope LoL cheesey
But i have a virtual oscillope on simulation.
10 2
the 155 ohm resistor simulates the ne555 + surrounding components (It takes 40mA at 9V. hoping it lineary, 40mA at 6.1 volt).
I set the IC running at 6.1 V, near the lower limit of operating voltage 4.5 volt.
Lower the voltage, bigger the resistor at vcc, so easier to smoothing using a small capacitor.
The VCC is 12V + 500 KHz AC noise 12 V, so 0 - 24 volt.
The output is around 6.1 volt (ripple 5.7 - 6.3 V)
The zener set the maximum voltage to 6.1 V
The diode near capacitor protect from reverse polarity (if any), i dont know this is be useful or not.
The 100 uF capacitor smoothing the ripple.
Any idea to add more protection for the IC?
I will rebuild the pwm tommorow.
hen918
Tue Oct 10 2017, 06:09PM
I put the design into Multisim (a nice NI front end for SPICE simulations) and found that it all looks quite nice. I had a bit of trouble getting the properties of the transformer right, so that the simulation would run. I ended up increasing the capacitance to improve efficiency and lower the frequency.
The 555 seems to be doing very odd PWM though. there seem to be two different pulse widths, one about the same size as it should be, and one far bigger. You can see that in the 'scope shot to the right, it shows the voltage on the primary of the transformer.
The scope to the left shows the voltage fluctuation on the power rail, assuming a 1 ohm internal resistance (cables, battery internals, etc). It isn't as high as I would have thought, but doesn't include the effects of induction, which you might encounter at 500kHz. As you can see, it's only significant at a PWM edge and is only about 1 Vpk.
1507659034 11591 FT1630 Sketch
Yunus
Wed Oct 11 2017, 03:02AM
what software you are using? It looks great.
i use falstad, web based simulator.
It soo CPU consumed when simulating a complex schema.
Tue Oct 17 2017, 04:45PM
Yunus wrote ...
Get one. Waveforms can't be guessed at.
Tue Oct 17 2017, 04:53PM
Patrick wrote ...
Yunus wrote ...
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=272515224943&category=104247&pm=1&ds=0&t=1507774343000&ver=0&cspheader=1
radiotech
Thu Oct 26 2017, 12:26AM
Why is the 68 ohm current limiting resistor in the earth lead of the 555 Timer ? Your timer
is un grounded, leaving it subject to all the garbage coming back from the base drive
circuit of Q3.
Put a bypass capacitor in parallel with the 68 ohm resistor.
Remember, zener diodes are capable of oscillating. When used in
radio circuits they are noise makers and are always bypassed.
