  • Guests: 31
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
UD3 development
Netzpfuscher
Wed Sept 06 2017, 11:39AM Print
Netzpfuscher Registered Member #1131 Joined: Mon Nov 19 2007, 01:36PM
I'm working on a new DRSSTC with the Psoc5 based UD3 driver. Perhaps we can use this thread to collect the progress and to collect new ideas.
My progres so far:
- Small changes to the PCB for cost reduction
- Support for USB (USB-Serial and USB-MIDI)
- New autotuning function
- Added maximum primary current to telemetry
- command line for control and configuration with help text, autocomplete and history function
Todo:
- integrate my polyphonic MIDI interrupter project to the UD3
- autotuning for secondary coil
- code cleanup
Terminal:
1504697451 1131 FT0 Terminal
Response of autotuning function:
1504697451 1131 FT0 Autotune
Track and hold for current measurement:
1504697451 1131 FT0 T And H
PCB:
1504697541 1131 FT0 Pcb1
PCB:
1504697575 1131 FT0 Pcb
Hydron
Wed Sept 06 2017, 06:33PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
It is good to see new work being done on DRSSTC drivers - I am also planning on making my own (am currently doing development on a FPGA plus modded UD2.5).
With the UD3 it is difficult though as the design does not seem to be public. Has Steve etc given you design info privately?
Netzpfuscher
Fri Oct 20 2017, 08:23PM
@Hydron
Yes i wrote him a E-Mail
I made a huge code rewrite. Now runs FreeRTOS on the Psoc. Everything runs in separate Tasks:
-UART Communication Task
-USB Communication Task
-UART Command line Task
-USB Command line Task
-Analog Task
-Status Overlay Task
-Fail Task
-MIDI Task
The MIDI Synth is running in Software (DDS) which has full control over every pulse. It can handle up to 8 simultaneous notes. The pulses that are generated are fed into a FIFO buffer. A timer loads a new pulse if the old pulse is finished. With this FIFO only one pulse can play in one timeslot.
I extended the autotune function. With a small hack I added a CT for the Secondary and I used Braille characters to display a chart on the console.
Primary without secondary
Wa0045
Secondary
1508530536 1131 FT180512 Sec
The firmware on the UD3 is updatable over the fiber link and I build a small PC interface. The PC interface connects via USB and enumerates as Serial port for the console and a MIDI Device. It packs the serial communication and the MIDI-Messages in a 1 Mbit stream over the fiber link to the UD3.
futurist
Sun Oct 22 2017, 01:11PM
futurist Registered Member #61400 Joined: Sun Jan 01 2017, 01:01PM
I love the console charts :)
How do you adjust phase lead and how does the autotuning function work?
Netzpfuscher
Thu Oct 26 2017, 06:39PM
The autotuning sweeps the given frequency range and measures the current in the primary and in the secondary. After a full cycle the function search for the peak and displays it.
The phase lead is Steves work and works with timers and DMA.
I finished a bigger bridge with 200A Semikron IGBTs
Wa0026
