  • Guests: 31
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Smoke und fire after switching on old electronics TEK DSA 602
Physikfan
Tue Aug 01 2017, 11:51AM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
Hello friends of electronics
A dealer for used electronics supplied me two Tektronix 11000 oscilloscope frames, DSA 602 and DSA 602A.
I was of the opinion that the devices were checked at least once before delivery.
I switched on the devices in a large exhibition hall to test the frames and some 11000`s like 11A72 etc.
That was not very smart.
After approximately 5 to 10 minutes after switching on, one of the devices worked electrically initially faultlessly, biting smoke came out from both devices, which greatly influenced the air quality in the exhibition hall.
Even one of these devices started to burn inside.
After extinguishing the fire, the dealer agreed not to have checked the equipment before loading.
However, every experienced electronics engineer should know that one should deal very carefully with a very long time of unused HP and Tektronix devices.
You should first connect these devices to a variable mains supply and the full mains voltage should applied step by step only after 2-5 minutes, in order to re-form various capacitors and to avoid potential explosions etc.
I would be interested in whether someone has already had similar experiences with smoke and fire when switching on old electronics.
The only positive thing followed this action was a corresponding price reduction.
You will get some pictures of the burned parts soon.
I hope I get from you also some hints how to repair these devices.
The documentation of the Tek devices is unfortunately not sufficient in the 11000 series, in contrast to the 7000 series.
Best regards
Physikfan
Tue Aug 01 2017, 12:16PM
Variacs are excellent tools but I prefer putting a high wattage mains voltage filament lamp in series, (especially for smps, which does not apply here)
I expect to see a brief flash from the lamp at power-on due to caps charging etc.
then a dull or no glow for normal operation, and fully bright if things go wrong.
The current limiting provided by the lamp usually protects from fire etc.
A switch contact across the lamp allows full power operation once you feel comfortable.
When we see what was damaged other ideas may come.
johnf
Tue Aug 01 2017, 07:05PM
usually it is the electrolytic capacitors depolarising---acting like short circuits this takes out the rectifiers and they go short circuit and now the ac on the DC rail kills at random.
the other failure mechanism is a shorted turn in the mains transformer due to green spot
DerAlbi
Tue Aug 01 2017, 09:40PM
Reforming old capacitors is perfectly possible, but i dont see how this can be done in a working device. Once you supply enough power for the operation of a device there is no way to limit the heat of the capacitor leakage current. So its a well meant thought having a light bulb in series, but it simply does not work like that.It only works if you put in a 50k resistor and dont turn the sucker on. But most poer supplies have some StBy power drainage so there is also no use.
Fri Aug 11 2017, 05:18AM
Same here. I think the correct method is to use a variac in series with load.
Physikfan
Fri Aug 11 2017, 02:34PM
Pictures of the damaged DSA602:
 MG 0001400x270
DSA602
 MG 0008400x254
Power supply from the side
 MG 0011400x313
Power supply from the rear
 MG 0013400x543
Rear of rear cover plate
 MG 0015400x305
smoked components
I am looking forward to your comments
Hazmatt_(The Underdog)
Fri Aug 11 2017, 04:05PM
Yea that's one of those clear WIMA mylar caps. Boy they sure do go up in flames don't they.
I had a couple do that, made a real mess of things. It's just the line input filter though. You can see the surge clamp tube under the char.
Just start rinsing the soot off with IPA, assess any actual damage, and replace the cap with a .01uF 600V PP type WIMA.
The smoke however, has permeated every nook and cranny of the scope though, you will probably need to rinse every part of that guy.
You ought to replace that clear one next to the inductor in the upper right corner as well for good measure (even though it never sees any AC)
I don't envy you having to deal with the smell, but it will eventually dissipate, that scope is going to stink for a while though.
Hydron
Fri Aug 11 2017, 06:08PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
If it's the line input filter then wouldn't an X or Y cap (depending on location) be a better idea than just a standard 600V PP cap?
And yes, those damn caps are terrible, have seen bad ones a number of times myself (though nothing with dramatic flames!)
Physikfan
Fri Aug 11 2017, 07:28PM
Images of parts of the smoking and burning DSA602A:
 MG 0089400x295
Power supply board with defective filter X2
 MG 0098400x190
Filter X2 in detail, this component burned.
This board looks better than the non-firing board of the DSA402.
I am looking forward to your comments.
Sat Aug 12 2017, 04:45AM
Can you make out the value on the top of the cap?
Keep up the good work.. you should be able to salvage this one.
