  • Guests: 29
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
slash128 first DRSSTC build
first  2 3 4 5
slash128v6
Fri Aug 04 2017, 08:22PM
slash128v6 Registered Member #61415 Joined: Sun Jan 08 2017, 11:50PM
Nice! Yeah, I wasn't aware of how hot the primary would get. All my previous spark gap coil primaries never really got warm, but running 24KV @ ~50-100mA into the primary is a bit different than the much lower voltages and higher currents of a DRSSTC :) Phil suggested water cooling and I will probably go that route. Currently it does get fairly warm after a few minutes but I need a bigger variac before I can go much higher. Currently blowing the fuses at ~250Vbus...
slash128v6
Fri Aug 04 2017, 08:33PM
Oh and forgot about the rectifier question. Original that blew was a full bridge 75A 1200V module wired as two pairs in parallel. New module is an AEG PowerBlock:
1501878790 61415 FT180219 Img 0002
slash128v6
Mon Aug 07 2017, 08:18PM
Currently throwing 50" sparks on 120VAC input... Getting a new 5KVA variac this week to take it up to 240VAC :)
1502137084 61415 FT180219 Crw 8370
Tue Aug 08 2017, 06:55AM
slash128v6 wrote ...
Mads: question for you: in one of your videos it looks like you are using the OneTesla SD Interrupter. Did you make any changes to the firmware for your coil?
No, I did not make any changes and the sound quality is not perfect, it properly needs some adaption to the coil its being used at. The interface is very simple and not really useful when operating a coil, its cheap and simple, I only used it for ease of operation while we tested.
slash128v6
Tue Aug 08 2017, 04:14PM
Thanks for the feedback. I apologize for my lack of knowledge here, but what functions would you consider useful and/or required in an interrupter? What are you using, something custom or ? Thanks!
futurist
Wed Aug 09 2017, 02:22PM
futurist Registered Member #61400 Joined: Sun Jan 01 2017, 01:01PM
I use their older interrupter code, without lcd
I'm happy with it and only thing that is missing is the burst mode
Midi mode needs some minor details fixed to get better sound
Problem is in the way second note is handled. As far as I understand the code: if second note starts when first is playing, second pulse is added together and limited to max on-time set, which gives harsh "pop" sound
Example pink panther theme playing on my coil
Solution would be: if second note starts when first is playing, second pulse should start after dead time after first note stops. Counter that triggered second note should not be stopped
I'm not sure how to properly implement it in their code, and how long should dead time between pulses be
Hope someone could help smile
slash128v6
Thu Aug 10 2017, 02:44AM
Appreciate the info! I'm going to play with increasing the on-time as well.
Got the bigger variac :)
Video: Link2
slash128v6
Thu Aug 10 2017, 08:33PM
Over 6 feet now :)
1502397185 61415 FT180219 Crw 8396
slash128v6
Fri Aug 11 2017, 02:57AM
~80"
1502420221 61415 FT180219 Crw 8406 80in
slash128v6
Fri Sept 22 2017, 07:00PM
Question on primary cabling: I am running about 700-800A peak and using 4AWG welding cable for the primary connections. The cables get extremely hot, but not melting the insulation, yet. But I am concerned about the leg passing through the OCD and FB CTs melting the insulation on those CTs. I could rewind the CTs on larger cores and run larger gauge cable, but before I jump the gun I wanted to get an idea of what others are running for their primary cables.
I have upgrade the MMC and watercooled the primary, so both of those stay nice and cool smile
1506106805 61415 FT180219 Img 0004
1506106805 61415 FT180219 Img 0005
first  2 3 4 5
