  • Guests: 30
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
slash128 first DRSSTC build
first  2 3 4 5
futurist
Wed Aug 02 2017, 07:43PM
futurist Registered Member #61400 Joined: Sun Jan 01 2017, 01:01PM
I was just finishing installing UD+ and did low power runs with dummy load like you
The current didn't seem to rise so fast so I changed prescaler in firmware for max. 300us on-time, but usually you run a coil at much lower on-times
slash128v6
Wed Aug 02 2017, 08:17PM
slash128v6 Registered Member #61415 Joined: Sun Jan 08 2017, 11:50PM
Cool. What driver did you change from, UD2.7? I think I'll see how the new inductors do tomorrow and then try to run it up at higher power and see how it does.
futurist
Wed Aug 02 2017, 09:19PM
UD2.7
Thu Aug 03 2017, 08:29AM
Swtiching spikes are always much bigger in ratio to the input voltage when you are testing at low voltage, since the IGBT capacitances are the same, but as Vce gets higher and higher, the switching spikes will look acceptable, as they always were, it just looks more dramatic at low voltages
slash128v6
Thu Aug 03 2017, 06:05PM
Thanks Mads! I should have new inductors today, so hopefully I can crank it up :)
slash128v6
Thu Aug 03 2017, 10:25PM
Mads: question for you: in one of your videos it looks like you are using the OneTesla SD Interrupter. Did you make any changes to the firmware for your coil?
slash128v6
Fri Aug 04 2017, 02:51AM
Good news: the SLOT TEN-5-10 worked perfectly for my coil!
Bad news: I blew my bus caps somehow... :(
1501815067 61415 FT180219 Ds1z Quickprint18
1501815067 61415 FT180219 Ds1z Quickprint22
slash128v6
Fri Aug 04 2017, 12:32PM
I panicked too much. After careful testing I found it wasn't the bus caps but the main rectifier.
Some video, still on lower power: Link2
slash128v6
Fri Aug 04 2017, 06:38PM
As an aside, "midget" style (10mm) fuse holders make great primary taps for 3/8 copper tubing.
1501871920 61415 FT180219 Img 2268
1501871920 61415 FT180219 Img 0003
futurist
Fri Aug 04 2017, 07:31PM
Nice ZCS!
I made similar tap point by soldering those fuse holders directly to 16mm^2 welding cable
Looks a bit ugly after many tunings
1501875092 61400 FT180219 Tap
Beware that primary will get hot at higher current runs and melt those plastic clips
What did you use as rectifier?
first  2 3 4 5
