  • Guests: 19
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Liquid Oxygen.
cherokeej
Sat Jul 29 2017, 09:55AM
cherokeej Registered Member #61554 Joined: Fri Apr 07 2017, 11:23AM
Very experienced rocketeer here...
Be careful playing with hybrids. A lot of folks are under the incorrect impression that hybrids can't CATO. They can, and do. Destructively.
Plasma
Sat Jul 29 2017, 09:47PM
Hi Patrick, hybrid are classed as 1.3 as they want explode but deflation, 1.1 stay away from. Hydrogen peroxide is a easy system and as the same ISP as lox but the delta vee for lox is higher, meaning more astride or a heavy payload.
The stages to get more ISP doesn't increase by much, I think about 330 ISP will get you into orbit, and it's other system and business ideas that will make a difference, for example solid rockets don't have much ISP, 200max so just space but they are eclenting at atmosphere pressure.
You need 350isp and as cheap as possible, but with a low earth orbit system for construction and multiple trip refuel.
Mon Sept 11 2017, 06:30PM
Any rocket type should be considered a hand grenade till proven otherwise, limited in destruction only by the available chemical energy. I have seen this first hand.
and launching from above 70,000 ft, using the rockoon method makes me feel better anyway.
