  • Guests: 16
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Audio Analyzer HP 3561A
Physikfan
Fri Jul 07 2017, 11:07AM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
With the help of a microphone and this analyzer, I would like to record the noise of a running three-phase motor connected to a frequency converter.
DSC08390400x279
The internal calibration signal (4 kHz rectangle) can be seen in the lower picture,
the upper picture shows the corresponding Fourier spectrum.
DSC08389400x300
Fri Jul 07 2017, 03:31PM
I think that you would learn a lot more if you
. use an ultrasonic probe or accelerometer
. analyze the voltage (e.g. Link2 ) and current (e.g. Link2 )
a simple ferrite ring current transformer will reveal all ....
Physikfan
Fri Jul 07 2017, 08:24PM
For the current measurements I will use the Tektronix P6042 current probe:
bandwidth DC to 50 MHz, risetime 7ns
P1760076400x243
Sat Jul 08 2017, 03:50PM
A blast from my past .. '70's ... nice bit of kit.
From memory, it needs de-gaussing frequently.
Physikfan
Sun Jul 09 2017, 11:21AM
My first experiments with the HP3561A I have done with a 15 $ microphone from Renkforce (100 Hz - 10 kHz).
The vowels A, E, I, O, U (logarithmic scale on the ordinate, abscissa frequency 0 Hz to 2 kHz).
A:
ALOGIMG 3196400x325
E:
ELOGIMG 3197400x322
I:
ILOGIMG 3198400x308
O:
OLOGIMG 3199400x308
U:
ULOGIMG 3200400x301
Regards
Physikfan
Physikfan
Wed Jul 12 2017, 03:26AM
hello Sulaiman
In addition, I have seen such a working part (HP 3561A) at a flea market for around 400 euros.
VG
Physikfan
