  • Guests: 33
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
"Flyback" Mode Flyback Driver Design
Fri Jul 07 2017, 05:25PM
it would be more fun to watch a video of the first time that you test it ;)
videography example Link2
Mr.Warwickshire
Fri Jul 07 2017, 10:42PM
Mr.Warwickshire Registered Member #61674 Joined: Mon Jul 03 2017, 04:01AM
It ran okay first try with an IRFP260N. Only problem was that the TVS diode across the mosfet was getting HOT.
Sat Jul 08 2017, 08:47AM
There are two likely causes for the TVS heating;
1) each cycle the capacitance of the TVS is charged and discharged, the resultant charging and discharging currents heat up any resistive/lossy parts of the circuit
- the TVS and the transistor.
This loss/heating can be eliminated by putting a suitable diode in series with the TVS.
2) A more significant source of your TVS heating is probably
Sulaiman wrote ...
One big problem with 555-flyback inverters is
what happens when energy is pumped into the primary every cycle but there is no load on the eht output ?
(this is important to understand and design for, in my opinion)
Hazmatt_(The Underdog)
Sat Jul 08 2017, 05:06PM
here's my design I did in 2005 for design comparison if you want.
This was designed for lower power to drive a Crooke's tube without generating too much X-ray for the kids science center. We had a hard time keeping
the tube ignited because it was over 80 years old.
If you want lots of power, you need to design for a push-pull, half bridge, or full bridge and use something like the SG3525 or TL494.
Anyway, hope this helps.
1499533573 135 FT180096 Flyback
1499533573 135 FT180096 Simpleflyback
1499533573 135 FT180096 Flybacktestsetup
Mr.Warwickshire
Sun Jul 09 2017, 02:17AM
Okay thanks for the schematics. I have replaced the IRFP260 with a 600v 50amp mosfet. I tested it and it works great with nearly zero heating of the transistor. I don't need the TVS either (atleast not until 50+ volt input) so I don't have to worry about it melting. BUT when I do run it above 50v I will try putting the diode in series with the TVS to see if that helps. I have yet to try it on a dc flyback. Just my hand wound AC ones. My DIY high frequency XRT works amazing on this driver. There is about 3-4cm of corona coming off the output wire when I run it at 25ish volts. I'll see if I can get a picture of it and post it on the projects section. Thanks for the help!
