  • Guests: 19
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Ringing on GDT. Can it be stopped with RC snubber? (no choice but to dupilcate)
Gregary Boyles
Tue Apr 18 2017, 05:53PM Print
Gregary Boyles Registered Member #9039 Joined: Wed Dec 26 2012, 03:31PM
If so how do you apply RC snubbers to this schematic:
MiniSSTCfnlsch
I tried puting one in parallel with the GDT primary (1k + various caps) but it seemed to have littee effect on the ringing.
220R for R4 & R3 seemed the flatten out the ringing but then I am significantly reducing current to the FET gates.
GDT:
4 strands of AWG 30 twisted together to form 3 'wires'.
3 of these are then twisted together to form a trifilar 'wire' which was then wrapped around the torroid.
Torroid material: N30
1492538039 9039 FT0 Gdt
Ringing on GDT primary
1492538039 9039 FT0 Gateprimary
Ringing on both GDT secondaries with peak voltage one lower than the other. Why?
1492538039 9039 FT0 Gateseondary1
1492538039 9039 FT0 Gateseondary2
johnf
Tue Apr 18 2017, 08:03PM
first put a 10K resistor across each gate to source
second put RC snubbers across D1 and D2 as you have not given details of your oscilloscope settings I cannot help further
Gregary Boyles
Wed Apr 19 2017, 06:56AM
johnf wrote ...
The oscilloscope is on the 1us scale, although there doesn't seem to be any way of telling how much the fine scale adjustment alters the time scale.
Resistor from gate to source? Oh I see what you mean - a discharge path that does not have to go through the GDT secondaries (inductors)
I was assuming the ringing was coming from the GDT but you have made me realize that it could be coming from the Tesla primary.......which would explain why trying various combinations of resistor + cap across the GDT secondaries was having little effect.
hen918
Wed Apr 19 2017, 10:37AM
Increasing the value of R3 and R4 can be used to reduce ringing, but it increases the switching times of the IGBTs, so it's a balancing act.
Gregary Boyles
Wed Apr 19 2017, 11:34AM
hen918 wrote ...
What is your view with this non-dissipative snubber circuit?
Snubber
https://www.daycounter.com/Calculators/Snubbers/Snubber-Design-Calculator.phtml
Is there any reason why it would interfere with the correct operation of this particular circuit?
And I assume I could get away with 1N1819 as D2 since the current involved with the voltage spikes would be under 1A.
hen918
Wed Apr 19 2017, 02:25PM
The snubbers on the daycounter website are design to prevent flyback on the output of the 'FETs. You seem to have a problem with ringing on the gates. This is due to nasty parasitic capacitiances and inductances between the output of the gate drivers and the inputs of the MOSFETs.
One thing you can try is placing a small value resistor in series with the primary of the GDT. I would suggest trying 2 to 5 ohms.
On another note, your duty cycle seems to be more like 60/40 than 50/50. This is causing the capacitor to shift voltages to maintain GDT flux balance. To provide an even voltage, provide an even duty cycle.
Wed Apr 19 2017, 02:29PM
with no ac power to the output bridge,
connect C12 in parallel with C9 to see more like operational gate waveforms.
use a 10R 10W resistor in place of L1 if L1/L2 not ready.
Gregary Boyles
Wed Apr 19 2017, 05:01PM
hen918 wrote ...
I used this 555 astable circuit so that I could experiment with the duty cycle with a double gang pot for R1 and R2 plus 2 x 1.2k in series with both sides of the pot to fix the minimum and maximum duty cycles at about 10% and 90%.
Tim58
So I could experiment with the effect of duty cycle.
I also have a 300pF tuning cap in parallel with the timing cap for fine adjustments to the frequency.
I have marked the position on my enclosure of 50% duty cycle.
But I have noticed that it really messes up the wave form if I go below 50% duty cycle.
I have my control box connected to the coil and driver circuit via a 3m long lead so that is probably a source of some of the parasitic capacitance and inductances.
But I didn't really want to be standing right next the the discharge while playing with the controls.
I will try your small value resistor trick and see if that improves the waveform.
Can you also suggest a website that fully explains and details strategies for dealing with ringing in this type of circuit?
Gregary Boyles
Wed Apr 19 2017, 05:03PM
By the way the oscilloscope traces tend to drift a bit vertically and that probably accounts for some of the asymmetry of my waveform.
loneoceans
Wed Apr 19 2017, 11:45PM
Side note - if done correctly, using magnet wire can yield a good GDT with sufficient isolation between primary and secondary windings. However it's very easy to nick or stress the insulation, which can lead to a short especially with high bus voltages. As a result, I typically prefer using good (but as thin insulation as possible) insulated wire.
