  • Guests: 25
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Small powerfull IGBT's
wikus
Sat Apr 01 2017, 02:49PM Print
wikus Registered Member #58198 Joined: Sun Dec 27 2015, 11:15AM
Hi all,has anybody tried these IXXK110N65B4H1 for drsstc .They look amazing. I want to get some but don't know if I can run them at about 60Khz, the data sheet says 10 -30 KHz. Sure they will easily get to 60khz
Thanks any comments please.
]ds100502bixxk-x110n65b4h1-472976.pdf[/file]
ScotchTapeLord
Sat Apr 01 2017, 05:31PM
They'll do 60kHz easily. The 10-30kHz figure is probably based on continuous hard switching, whereas a DRSSTC low duty cycle/soft switched.
wikus
Sat Apr 01 2017, 09:47PM
Thanks Scotchtapelord I will try them and send feedback
Mon Apr 03 2017, 06:54AM
Do the math and you can easily find out how hard you can drive any IGBT, where you have sufficient data to calculate it. My IGBT guide for DRSSTC Link2
loneoceans
Tue Apr 11 2017, 12:06AM
IXYS makes very nice IGBTs esp their IXXX series, but they're typically quite expensive :) These look great for a small to medium sized coil.
wikus
Tue May 30 2017, 05:56PM
Hi guys just giving some feedback on the IXXK110N65 IGBT'S. I tried them in small DRSSTC running at 270Khz, half bridge at about 200-300 Amps. I ran it for 20 min non stop through all BPM. and on times and they didn't even warm up at all. The coil was producing 52 cm. sparks at 175 V input. In conclusion I think they are great and will now try them on a larger coil (124 KHz ) that I am still working on.
Thanks again for great site.
wikus
]my_drsstc_small.wmv[/file]
teravolt
Tue Jun 06 2017, 01:39AM
I also found these if you are still looking for a little more power.
and this
