  • Guests: 26
Shaun (34)
Spedy (30)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
15 uF, 20 kV oilfilled capacitor
Physikfan
Tue Mar 21 2017, 07:15PM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
A real heavyweight, I could lift the thing with only two arms:
Sbgkondensatortrim400x291
The energy when charging with 20 kV is:
Ec = 0.5 * 15 * (10 ** - 6) * (20,000) ** 2 = 7.5 * (10 ** - 6) * 4 * (10 ** 8) = 3000 Ws.
At the same time, this is approximately the energy of a mass of 10 kg after a free fall of 30 m height at the time of the impact.
Comparing this with the energy of the 10 nF 200kV capacitor:
Ec = 0.5 * (10 ** - 8) * (200,000) ** 2 = 0.5 * (10 ** - 8) * 4 * (10 ** 10) = 200 Ws
We can see that the voltage is higher by a factor of 10, yields 100 times more,
But the capacity is higher at the other by the factor 1500, which gives the difference!
If you charge a 6 F capacitor to 32 V, you have the same energy as in the 15 μF, 20 kV capacitor.
Enceladus
Thu Mar 30 2017, 03:27AM
Enceladus Registered Member #61428 Joined: Sat Jan 14 2017, 12:39PM
What are you using this thing for? Exploding melons? Projectile launch? Does it even belong to you?
Physikfan
Thu Mar 30 2017, 02:16PM
At the moment I am only wondering which charging voltage would neither destroy the capacitor nor damage the close environment.
Here is a picture of this capacitor:
HVC1342x400
