  • Guests: 15
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Experiments with 10 nF 200 kV capacitor
Physikfan
Thu Mar 16 2017, 10:54AM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
Nice item for high voltage experiments
10nF200kV1trim430x400
10nF200kV2trim123x400
Hazmatt_(The Underdog)
Fri Mar 17 2017, 03:43AM
If you had a 100pF 50kv doorknob cap you could make a useful high voltage divider, of course you would have to make a stand for the whole thing, I'm sure that capacitor is relatively heavy.
Physikfan
Fri Mar 17 2017, 08:50AM
Hi Hazmatt_(The Underdog)
I think to build up a voltage divider for AC by capacitors is a good idea.
"If you had a 100pF 50kv doorknob cap you could make a useful high voltage divider".
Using your 100pF 50kv doorknob cap and my 10nF cap, the 100 pF should be at the high voltage side.
To divide a voltage of 200 kV down to 100 V (2000:1) you would need a capacitor at the low voltage side of 20uF.
Regards
Physikfan
Fri Mar 17 2017, 05:17PM
I get things mixed up from time to time.
It's been 10 years since I built a capacitor divider.
Antonio
Sat Mar 18 2017, 03:05PM
Similar to a battery of Leyden jars. Good for classical experiments as exploding wires. Don't take a shock from it.
Physikfan
Sun Mar 19 2017, 11:53PM
This capacitor´s mass is 18.5 kg, the length is 110 cm and the diameter is 14 cm.
