  • Guests: 19
wpk5008 (34)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Large Van de Graaf
zrg
Sun Feb 26 2017, 01:12AM Print
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
So, having first met these wonderful machines about 6 month ago, I decided that I need a large one to have fun with.
2.5 meters overall height, 800mm sphere diameter, 250mm PVC tube.
Washing machine brushed ac engine, aluminium lathed rollers, latex band (15 mm wide), external HV supply.
Max sparks about 700-800 mm long, limited by sphere's edge curvature. I have no idea how to bend it smooth enough. Maybe I should try attaching an external toroid to it...
1488071571 4762 FT0 8b41lgogbzc
1488071571 4762 FT0 Knnygaks6dy
1488071571 4762 FT0 A6axjms3c5i
1488071571 4762 FT0 Pkhvebs0pfa
M7oudse
1488071571 4762 FT0 Whyorrfp2wc
1488071571 4762 FT0 21kzsnfmx0k
1488071571 4762 FT0 Ctlr Dy4rcu
1488071571 4762 FT0 Glesjwuhpa0
1488071571 4762 FT0 Nubjgmshp5k
1488071571 4762 FT0 Ridlblplutg
1488071571 4762 FT0 Mckyo7xvdru
woodchuck
Mon Mar 06 2017, 03:10AM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
Cool!!
alan sailer
Sat Mar 11 2017, 02:44AM
alan sailer Registered Member #59110 Joined: Mon Apr 11 2016, 04:35PM
Nice.
I gave a friend with a small van de Graff a few small (12mm dia) glass plasma tubes (2mm wall) and he managed to punch a hole in one of them near the seal point.
So be careful with your lovely plasma glass near this vicious vacuum killers smile
I guess that the peak current is kind of high.
Cheers.
Sat Mar 11 2017, 09:13AM
Very nice.
The top terminal shape is wrong, it should look more like this
1489223581 162 FT179121 Vdg
KeeDx3
Mon Mar 13 2017, 04:20AM
KeeDx3 Registered Member #61435 Joined: Thu Jan 19 2017, 06:46AM
Sounds like you're using an HV "exciter". I had only read about it and have never seen anyone build one. What are the specs on the HV supply? I have heard of people using one end of a neon sign transformer.
Having tackled the Jacob's Ladder and now in progress on a smallish Tesla Coil, I think the Van De Graaf will be my next project. I have an old bandsaw motor that I may use - unless I find something with higher RPM (I think the one I have is 1350). Out of all the projects, it seems that VDG's are the most fussy.
You might be able to mitigate the streamers at the base of your electrode by employing a few different methods. If the cut is sharp, try taking some pliers and rolling the edges in a bit. You might even find some sheet metal tools designed for folding edges. Failing that, file any sharp edges. Seems like I have read about people using a rubber trim material to "finish" the edge. I believe that's what PhysicsPlayground does on his VDG's and they apparently perform well.
zrg
Mon Mar 13 2017, 02:45PM
Sphere's edges are not sharp, as I managed to bend them inside a bit, but the curvature (not more than one inch, I think) is obviously not enough to expand this construction's possible efficiency and max voltage. Unfortunately, I have no idea of tools capable to do the job. That's how one of failed attempts (on another sphere) look like: Link2
Chinese are able to make custom toploads according to the drawing Link2 but the prices are a bit high to afford it.
