  • Guests: 25
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Mach 1 over a weekend
Sun Jan 22 2017, 08:16PM Print
I've always been interested in vacuum cannons but only recently found out that with a high pressure boost
it is possible to get objects up past the speed of sound. (The current record is over 800m/s)
So after a quick trip to the hardware store I built myself a pressure+vacuum cannon with vacuum accumulator.
The I put a wire along the mylar foil on the high pressure side as a trigger, if it fails to fire from pressure I can
just heat it up but as of yet it has always fired on its own. The vacuum accumulator at the business end is used
to eliminate any back-pressure from air that blows by the ping pong ball as it accelerates.
1jXu9t6
After a few attempts I finally got a ball going at 360m/s! "Fast" doesn't cover how short the event is, the ball
is evaporated before you get a chance to process what has happened.
GIFV: Filmed at normal speed and 1200fps
To estimate the speed I (previously) measured the displacement between the target and the barrel and then was
able to measure how far the ball moved in 1 frame (about 30cm). The shutter speed was 1/1250s but I'm not sure
how much rolling shutter caused the streak to be lengthened so I am calculating conservatively.
HfnV3lF
The next step is to build a target enclosure to catch all the ball bits and target material that comes flying off.
johnf
Mon Jan 23 2017, 06:23PM
I saw a vacuum cannon at HEAS a few years ago. That one went more than 1 Mach iforget how fast but the noise was stunning. The ping pong ball went through full sodapop cans (filledwith water). No need for accumulator but the unit did have a potato cannon to help it along
Tue Jan 24 2017, 11:06AM
I my pressurized air boost is pretty much a potato cannon so it sounds like a similar setup. Looking at my high speed footage I can see the exit burst disk puff up just before the ball exits, indicating back pressure. I thought that the vacuum accumulator would take care of this but maybe I just haven't let it pump down far enough.
440m/s run filmed at 1/1200fps
Is HEAS a makerfair/con/thon? I couldn't find it from a quick google.
johnf
Tue Jan 24 2017, 05:56PM
HEAS = high energy amateur scientists getotgether late Sept early oct once a year
run by Richard Hull in Richmond Virginia.
Two stage vac pump took around ten minutes to evacuate the tube
Tue Jan 31 2017, 02:55PM
Interesting.. This could be a great tool to visualize to what extent air is in the way of moving objects.
A couple of questions:
How thick is the mylar you use as diafragm?
How high pressure is in the pressure chamber?
How do you sequence the breaking of the 2 seal, pressure vs vacuum?
Cheers, Finn Hammer
Tue Jan 31 2017, 06:06PM
It would be interesting to run it with varying levels of vacuum and see how much of a difference there is in the ball speed. At the moment I am getting about 40torr according to my amazon vacuum gauge but I think there are some leaks in the non-vacuum rated hose I am using.
The mylar I am using is sometimes known as "space blanket" and my crummy micrometer measures it to be ~15um.
At the moment I haven't had it above 80psi due to the length of airline between the cannon and my compressor, with the ABS I picked I can safely go up to 100psi with no fear of failure.
I have changed the setup a little and am now using only one membrane at the vacuum/pressure interface (having 2 was causing issues). My new membrane is made of poly propylene tape (tuck tape), a length of 30awg wire, mylar and then another strip of tape. This will easily hold the 80+psi and can be triggered by heating the wire with a little current, once the mylar and poly propylene have weakened they fail in a catastrophic way and release the pressure.
My last shot came out around 500m/s and put a measurable dent in a hard hat!
RL1i0Xf
(1200fps, 1/2000s shutter speed)
