  • Guests: 13
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
Old double prism spectrometer
Physikfan
Fri Dec 09 2016, 05:09PM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
The pictures show an old separable double prism spectrometer in a wooden box.
SpektrometerA1400x292
Spektrometer2400x343
SpektrumA3400x184
Spectrum of a compact fluorescent lamp, (mercury).
Sat Dec 17 2016, 01:12AM
Marvellous! :)
Karmaslap
Sat Dec 17 2016, 08:54AM
Karmaslap Registered Member #58215 Joined: Wed Dec 30 2015, 11:27AM
Where did you find it?
Sat Dec 17 2016, 10:38AM
I found this scheme for a simple spectroscope which looks a good start for experiments:
Physikfan
Sat Dec 17 2016, 04:35PM
Hi Karmaslap
I found this spectrometer at a flea market many years ago.
Physikfan
Sat Dec 17 2016, 04:49PM
Hi Proud Mary
in my post "neon spectra by transmission grating" of October 25, I have used almost exactly the same procedure:
a transmission grating in front of camera with a telefoto lens.
I have used the small capillary of the spectral tube instead of an additional slit.
If you compare the spectrum of the energy saving lamp of your source (Maurice Gavin) with the spectrum of my fluorescent lamp you see an excellent correspondence:
Spg6ytrim
transmission grating spectrum, copyright Maurice Gavin
SpektrumGDA3400x184
double prism spectrum of a compact fluorescent lamp, (mercury).
Due to the high dispersion (d n/d lambda) of the prism in the blue region the relative distance of the two blue lines of the prism spectrum is larger than the equivalent relative distance of these lines of the grating spectrum.
Sat Dec 17 2016, 06:10PM
Good stuff!
