  • Guests: 21
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
secondary resonance vs working frequency of the secondary coil
Sat Nov 11 2006, 09:05PM
AFAIK most people buld a TC to get impressive/spectacular arcs
the result will be (mostly) determined by power throughput
so close-coupling, large topload etc. works best.
Tesla didn't want corona/sparks/arcs, high-voltage high-capacitance was more his thing
(wireless transmission of power etc.)
Terry, your graphs clearly show the wavelength characteristics of your resonator;
the coil with topload (toroid similar to coil ... operating below 1/4 wavelength)
shows a nearly linear volts/inch - lumped model reasonably accurate.
the unloaded coil clearly shows the tapering off of volts/inch near the top
if you extrapolate the centre region of the slope
you should get about 90 kV at the topload instead of 70 kV
signs of non-lumped operation.
The resonance effect of Inductance and capacitance
is more significant than the 1/4-wavelength effects
so for practical high power long arc TC forget wire-length effects
and operate well below 1/4 wavelength resonance. (large topload)
but the effect is real and present.
Thu Nov 16 2006, 06:45PM
The permitivity of the conductor 'slows' the wave speed down, and if you look this up in a Belden catalog its something like .66 * speed of light, and that also varies between cables too.
so f = c/v; yea, for light and ideal cases, but not so much here.
So, if I wanted to resonant coil of my secondary with the top load to match the 1/4 wavelength frequency should I use 66-80% the speed of light for the calculation? Does anyone think this will truly affect coil performance?
Thu Nov 16 2006, 06:56PM
As said, it won't. Just calculate your inductance, self-capacitance and topload capacitance to get your resonant frequency out.
Thu Nov 16 2006, 08:28PM
If you design your topload to resonate the coil at the 'quarter vavelength' frequency
(assuming c=speed of light in vacuum)
you will certainly be in the right area (below 1/4 wavelength) due to v<c.
So using the speed of light in vacuum with the length of wire to (wrongly) estimate 1/4 wavelength operation the coil will be almost a lumped equivalent/at a good frequency.
Adding a second tuned circuit (the primary) causes frequency-splitting anyway
so the 'operating' frequency will be neither 1/4 wavelength nor 1/2.pi.sqrt(LsCs)
teravolt
Fri Nov 17 2006, 05:27AM
unless your trying to make a tesla to a specfic frequency 1/4 wave is accademic. When I make a coil I just mesure it then use top load to tune it. Of more inerest is frequency splitting and tuning low.
