Registered Member #3450
The bulb glows green on the inside when exposed to HV from an ignition coil. I only did this for a very brief moment to get the photo. Also, I had my Ludlum model 3 survey meter which screamed when I turned the ignition coil on. The meter was ~10ft away, I figured the electrical noise from the ignition coil may give a false reading.. Could this actually be producing X-Rays?
Registered Member #39190
Kaye, in his book "X-Rays" describes an apple-green glow on the walls of soda-lime glass. Your pic seems to fit the description. The report of your Ludlum meter seems to buttress such a hypothesis. I'd say, yes!
Registered Member #230
No it will not be producing x-rays. The glow is ionised argon gas in the bulb lighting up the glass. Glass stops x-rays up to 20keV. Your survey meter is better at picking up electrical noise than it is capable of responding to gamma /x-ray. remember its threshold is 35millivolt so any disturbance over this will be a count.
Registered Member #60240
Polonium210
You can check the existence of x-rays:
the simplest way is to put a lead or iron brick or at least a sheet of lead between your bulb and the detection device.
Please do not change the distance between your source and the detector.
If you see a significant change of your "gamma" intensity, then you have really x-rays. If there is no change your detector may probably receive the "electric noise" from your pulsed high voltage source.
You should measure the voltage of your source, at least the maximum of the spark length to calculate the possible energy of your x-rays.
Registered Member #162
I agree that your detector could be picking up electrical noise but I suspect x-rays, ignition coils are rated for 25 - 35 kV and can produce more crt tv tubes have had barium- or lead-loaded glass fronts since 10 kV b/w days because of x-ray hazards.
Maybe a digital camera with black tape or paper over the lens will show the x-rays, to settle the question ?
Registered Member #2099
Yay for the scientific method. That last experiment was a good one. Another would be to run the whole apparatus inside a metal enclosure (garbage can?) as an RFI shield. See what the rad meter says. With an opening in the purported shield, do you get behavior consistent with streaming x-rays (scattered by air)?
Your pictures are reminiscent of a classic Amateur Scientist column in Scientific American, I think the July 1956 issue, "An Inexpensive x-ray machine". found here:
That tube, or your bulb, could not be an argon-filled type. It would have to be evacuated but not very well evacuated.
Switch on your ignition coil with the bulb, switch on your gamma detector, distance between them about 50 cm. And then put a metal box or at least an aluminium sheet between bulb and detector and watch the display of your detector.
Is there a significant change of the counts/second or not?
