Registered Member #60240
Hi
I have two commercial induction coils by Leybold, 10 cm spark length, 250 windings at the input side and 26 000 windings at the output side.
Both induction coils are working with the Wagner´s hammer as well with a thyristor power supply.
But both secondary coils did not show an ohmic resistance measured with a low voltage ohm meter, DC 1,5 V Unigor or AC HP RCL-meter (1V, 110Hz).
For further experiments I have used both induction coils as normal AC transformers, applying AC voltage 50 Hz, 1 V to 10 V in steps of 1V at the primary coil. From 0 to about 4 V at the primary coil no signal was at the secondary coil. From about 5 V to higher voltages at the primary coil at the secondary coil a voltage was measured corresponding to the windings ratio of 26000 / 250.
What do you think about these measurements? Are there small interruptions of the wire in the coils which lead to small arcs which will destroy as a consequence the complete secondary coil after a longer use the induction coils?
Please, I would like to ask owners of induction coils to measure the ohmic resistance of their respective secondary coils and report their results in this thread. Also I am looking forward to your advice, experiences etc.
Registered Member #834
A broken wire in the secondary is a (bad) possibility, but a bad contact in the sliding rod is also possible. Verify where are you measuring the resistance, and make it sure that all the contacts are good.
Registered Member #230
to measure the resistance will take quite some time with an ordinary multimeter as you are fighting the huge inductance of the secondary (many 10's of Henrys) be careful when you remove the meter leads as a substantial shock can result by the collapsing magnetic field in the coil
Registered Member #2906
You dont want measure big inductances with a multimeter. This can become confused by the induced 50/60Hz hum. Depends on the multimeter of course. I would suggest you just put constant voltage over it and measure the current in dc mode to get a good resistance measurement.
Registered Member #2099
To determine the polarity of my first 60 Hz XRT, I put a neon glow lamp across a secondary winding and connected a 1.5 volt AA cell to the primary. Got a momentary glow on one electrode, as expected. The surprise came when I disconnected the battery. The opposite electrode glowed for a while, as the lamp clamped the output voltage of this ad-hoc flyback transformer.
Hi Antonio, johnf, DerAlbi and klugesmith
I have determined the resistance and the inductance of another fully working commercial induction coil comparable to the Leybold induction coils by measuring
1. the DC resistance and 2. the AC impedance at 50 Hz
and then calculating L.
induction coil spark length 120 mm
Here are the values:
Secondary coil: R = 25 kOhm Inductance 524 H windings ratio 1:230
Unfortunately I have no exact numbers of the windings of the primary and secondary coils.
The same procedure was not successful by measuring the two Leybold induction coils as reported in fy first posting.
Registered Member #4074
Physikfan wrote ...
Hi klugesmith
This is a very surprising and interesting experiment. I would like to reproduce your results. Please tell me what XRT means.
Regards
physikfan
In this context, XRT refers to an X-ray transformer, the high voltage transformer that supplies the vacuum tube in an X-ray imaging machine.
These transformers have a different construction to a HV induction coil, but have a similarly high turns ratio. They use a regular laminated iron core with no air-gap and produce anywhere from 50-150kV (requiring oil insulation due to the compact size) with a short circuit output current of approx 5-10mA. They are usually only intended to be powered for a few seconds, and will quickly overheat. However, there are some industrial X-ray machines that feature very powerful transformers capable of 250kV+ and many kVA.
