  • Guests: 14
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
[moved] Transformer oil and lights
Gordie Orange
Sat Jul 16 2016, 07:16AM Print
Gordie Orange Registered Member #55076 Joined: Sat May 23 2015, 08:26AM
I have a home built transformer (4 mots in a box) filled with transformer oil and a clear perspex top.
Question, is it possible to be lit on the inside and if so what sort of bulb would do seeing as there isnt much room in there
Sat Jul 16 2016, 08:32AM
LEDs seems like the obvious choice then
small, low voltage, high lumen output to size. etc.
Gordie Orange
Sat Jul 16 2016, 12:34PM
cool ill have a look for some dimable 230v leds
radiotech
Tue Sept 06 2016, 09:13AM
The external circuit to the lamps should be grounded to prevent any high voltage danger. Also, if you
chose a LED with a base intended for socket, you may not be able to keep the oil from leaking in.
The lamp may be also lighted by a few turns around the core.
