  • Guests: 8
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
HV stuff trade to 5 Phase Oriental steppers
Linas
Sat May 07 2016, 01:46PM Print
Hello,
Since i am collecting parts for CNC mill, i need some high end steppers, it would be best to use 5 phase stepper motors due to larger division of steps ( i will use 1um encoders for feedback)
I have SKM400GB125D and SK200GB125D igbt's, HV capacitors ,x ray tubes, lot of power mosfets in to-247 and isotop packages >500V
Tue May 10 2016, 06:19AM
Hi Linas
I got some different stuff, maybe you can use it...
Driver board C7576-004 with Vexta IC "EIC0202" and Vexta stepper motor 2-phase 1.8 degree/step DC 3A 1.5Ohm A5109-9412K: Link2
Some other driver boards and different steppers (From picture 147 to 152): Link2
Linas
Thu May 19 2016, 04:40PM
Well, after talking with Yoda equivalent, i should go not to steppers, or 5 phase steppers, but AC servos instead.
So better would be to get 3 identical AC servos at least and CNC Ethernet Smooth Stepper board for control, it looks it will give best results
macona
Sun Jun 19 2016, 04:11PM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
I recommend Yaskawa or Mitsubishi servos, Sigma III or newer for Yaskawa and MR-J2 or newer for Mitsubishi. They have real time auto tune which will make your life much easier.
Dont try to mix and match servo motors and drives, you will regret it. Most modern servos now use serial absolute encoders with proprietary protocols, but they offer insane resolutions, I have Yaskawa motors with 1 million count per rev encoders.
Mon Jun 20 2016, 06:49AM
Linas wrote ...
Do you have an idea of what Torque and speed you need? (or at least power rating?)
I do work for a motion control firm. I could see what we can do.
I assume pulse-direction in? (I personally recommend analog for such an application if you can find a suitable motion-controller.
It depends on how you want to set it all up.
Linas
Mon Jun 20 2016, 07:03PM
Thomas W wrote ...
Linas wrote ...
Already spend >1k for Teknic clearpath enhanced servos amazed
