  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
ZVS Flyback Tesla Coil Question
radicalsniper
Sun May 01 2016, 09:30PM Print
radicalsniper Registered Member #59251 Joined: Thu Apr 14 2016, 11:21AM
Hello, is it possible to create a SGTC being powered up with a ZVS Flyback driver?
Here is my take on my Tesla coil specs (I already built it)
Primary:
7 AWG Copper Conductor 15 Turns with 0.25" spacing
Secondary:
26 AWG Magnetic Wire 1177 Turns with 4" diameter pvc pipe
Top Load:
4" diameter Aluminum Ducting
Tank Capacitor:
12 Bottles with saltwater and oil on the inside (each bottle have 0.7~0.8nF capacitance)
I have tried running it.. the rotary spark gap is working (i think) but no breakout occurs..
See the attached fileformore info
]chapter-4_1.pdf[/file]
Platinum
Fri May 06 2016, 09:35PM
I would suggest using an MMC a capacitor bank made from a bunch of smaller capacitors, or find some nice high voltage capacitors. have a google at tesla coil calculators itll help you build a good MMC given that you input all your current coil dimensions, also salt water caps use just a conductive liquid. And rolled capacitors are better and still easy to make, good luck.
Blackcurrant
Sat May 07 2016, 08:06PM
I take it your Flyback drivers output is being rectified to charge up the tank capacitor?
You will know if your spark gap is working you will see and hear it.
Art
Tue May 10 2016, 03:51AM
Art Registered Member #57369 Joined: Fri Sept 18 2015, 01:24PM
If you take a small pigtail neon and earth it’s leads to a sheet of foil on the ground, and suspend it near the coil so it lights with minimal power, you can then tune for maximum brightness and at least find if your primary circuit has a resonant spot, The whole time running at low power so as not to damage anything.
