  • Guests: 12
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Optic Interface
Art
Sat Apr 23 2016, 06:58AM Print
Art Registered Member #57369 Joined: Fri Sept 18 2015, 01:24PM
Hi Guys,
I’ve seen an optic interface from a control box to a Tesla coil a few times,
one of them in one of Photonicinduction’s YouTube videos.
I have a frequency generator written for a pic micro, with LCD and hardware serial interface working,
and now am looking to use serial over an optical interface instead of the pair of wires.
Assuming some people here would have already done this.. questions...
Is a standard serial protocol usually used?
Is Toslink physical hardware usually used (same as SPDIF interfaces for audio)?
Cheers, Art.
Edit: I’ve had success making a 2400 baud serial connection
with Toslink hardware receiver buffered through a 7404.
Looks like I’ll have an optical connected keypad :)
Phil33ts
Mon Apr 25 2016, 04:07AM
Phil33ts Registered Member #57473 Joined: Sat Oct 03 2015, 03:21PM
I was thinking about doing the same thing. Can you share your code and schematic?
Art
Mon Apr 25 2016, 07:55AM
Hi :) Neither are really ready, I only got it reliable enough tot send a text file with no errors last night, and only have tried 2400 baud.
This schematic isn’t up to date. It was only reliable once I added a 7404 and buffered the receiver’s signal with that.
The code is in Picbasic Pro, and won’t compile without it. Mostly in assembler for midrange pic, but I use PBP for it’s canned LCD routines.
Phil33ts wrote ...
Tesla Schematic Zpscuyuwtsk
Mon Apr 25 2016, 03:26PM
What transmitters and receivers are you using?
Most Toslink components are AC coupled and can only receive down to 0.1Mb/s or so. You also have to ensure DC balance in the signal you are trying to transmit.
Art
Mon Apr 25 2016, 11:52PM
HI :) The receiver I salvaged from a box that converted optical to coax.
It had a capacitor in series with the signal path of the receiver,
and I removed that, and instead used a 0.1uF cap between the signal path and ground.
The transmitter at the moment is a high intensity LED.
The transmitter outputs true, so I used two inverters of the 7404.
