Registered Member #2431
I'm conducting some experiments, and will post some already completed here shortly, based on corona and entrained air.
But in my effort to explain the specific math, physics and chemistry at work, ive run into the complication of generating the corona itself.
So, lets say the atmosphere is 78% N, 21% O, and 1% Ar. And then we have a HV point near a grounded sphere, we generated a corona, but no arc or sparking.
What percentage of these gases would be in there first ionization energy ? And then their 2nd energy ? Do they all, or almost all have to be ionized to the first level before they can go to the second? or would it be possible for there to be a fractional "zoo" of this species flying about ?
Registered Member #53
If you have a diffraction grating it might be possible to record the spectrum and try to identify the ions present by that spectrum. You would have to have some light source, or sources with a known spectrum to callibrate against but it is doable by on a hobbies level.
I cant get that PDF to open, but am I basically asking about singlets and doublets ?
I just wonder how ill get sensitivity at the hobby or college level, to sort out a population, unless its singlet common, and doublet/triplet uncommon.
the first Ionazation energy is just 39% of the second. so if the population of doublets is high, it needs to be accounted for, but if rare, like 0.000001% then it wouldn't matter much in my calculations.
Registered Member #162
AFAIK ionisation, oxidation etc. proceeds in stages, e.g. to get to 'level 2' you go ground, step1, step2 ... so maybe if you can remove the first ionisation level species quickly you should get much less level2 etc. e.g. a very thin stream of high speed air such that only a small fraction of the molecules are ionised, then analysis MAY be easier.
Sulaiman wrote ...
. . . e.g. to get to 'level 2' you go ground, step1, step2 ... so maybe if you can remove the first ionisation level species quickly you should get much less level2 etc. . . .
I'm wanting to produce as much corona possible in singlet, from a high speed moving airstream. so I hope this works as a whole solution, not just for the spectrum analysis. Hopefully this will heap.
My camera is recording things excessively yellow, so I don't know why that is. But ive chosen oil here as its easy to visualize, but my real interest is in air flow.
Registered Member #193
Patrick wrote ...
AFAIK those are the ionisation potentials for the atoms and air is composed of O2 molecules.
The only hope you have of working out what is going on is via spectroscopy and that's going to be difficult.
Registered Member #54596
Patrick wrote ...
It works for me (Windows XP, Adobe reader 11). Page title is "An Investigation of Ionic Wind Propulsion". It's pretty basic, though. I don't see anything about percentages of ion species.
I think you can safely ignore double ions in negative corona. Since the electrons moving away from the electrode have to slow down before they can stick to anything, and would be repelled by any negative ions in the area, I'm not sure you'd get any double ions at all.
But in positive corona, the electrons rushing toward the electrode would be attracted to any positive ions in the area, so more likely to run into them and knock off a second electron. I have no idea what the actual percentage would be, but probably worth investigating further before ignoring it.
