Hamamatsu PMT module for sale
Pinkamena
Tue Apr 12 2016, 09:35PM
Registered Member #4237
Hello!
Selling something a bit out of the ordinary, a GaAs photomultiplier module from Hamamatsu. It comes with a mechanical shutter that connects to the front. This module consist of a temperature-controlled GaAs PMT inside a protective case. It also contain the high voltage system for the PMT, as well as thermistors. It's basically an all-in-one solution for photon counting. I have tested it, and it works perfectly. Naturally, being from Hamamatsu, it's a bit expensive, but if you're interested you can check it out here.
