  • Guests: 9
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Who supplies large toroids?
nzoomed
Mon Mar 14 2016, 04:04AM Print
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
I need a large one around 600mm x 150 (or larger)
Does anyone know of a good supplier?
Our metal spinners in New Zealand have only ever made small ones around 300-400mm in diameter.
I might have to make do with semi rigid ducting, but i would prefer something smoother.
TIA
Hazmatt_(The Underdog)
Tue Mar 15 2016, 01:30AM
There are only 3 I know of
Eastern Voltage Research < I bought their largest one, I was wonderful.
Information Unlimited < very similar products, pricing is similar
Ross Engineering Corporation < they have every size imaginable, but be prepared to pay for it, they are not cheap. You will have to email for a price schedule.
nzoomed
Tue Mar 15 2016, 09:47AM
Information unlimited seem to have a good range, but the cost is pretty high, especially after currency conversion and freight etc.
Ive been in touch with a local machine shop who will be able to make me the pattern for sending to the metal spinners who will be able to make me toroids for only $120 NZD each!
So im probably looking around $500 including the finished toroid and pattern to make more!
I wish the chinese would produce these, as we could get them real cheap from there.
loneoceans
Tue Mar 15 2016, 06:25PM
nzoomed wrote ...
They do produce them:
You can buy bigger ones by contacting them too :). But usually you need to buy 100 of them or more. :)
nzoomed
Tue Mar 15 2016, 07:35PM
loneoceans wrote ...
nzoomed wrote ...
Yes i had looked on alibaba, and saw smaller toroids available and they could make me some, but yes i had to pay to make tooling and buy 100 of the things to get what i want. Someone like eastern voltage research could do well from this.
I take it that you got yours made locally?
Im needing a similar sized toroid to the ones you are using on your coils. :)
Hydron
Tue Mar 15 2016, 10:45PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
If you're seriously looking at getting toroids made in NZ then send me a PM - could be interested in one myself. I used semi rigid ducting (think I ordered it from Corey's Electrical), but it dents super easily and doesn't look amazing.
nzoomed
Wed Mar 16 2016, 04:57AM
Hydron wrote ...
OK, sounds good.
I will be getting the metal spinners making them exclusively for me as i will be the owner of the forms.
I will be able to get you one made a darn sight less than importing from overseas.
What size do you need?
Im looking somewhere around 600 x 160
Once i get the quote i will be able to tell you how much i can get you one made for.
