  • Guests: 21
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
NATO TLD dosimeter reader
Wed Mar 09 2016, 02:44AM Print
Here is the "Computer Indicator Radiac CP-696" for the NATO wristwatch style TLD dosimeters that appear so often on ebay. The TLD watch - with its cover unscrewed - goes in the drawer at bottom right. Note that the dose readout is in cGy, so you won't get a sausage from background radiation.
1457490905 543 FT0 Fisher Dosimeter Reader
Wed Mar 09 2016, 06:25AM
I will have a check around to see if my crystal is still here.
Wed Mar 09 2016, 09:57AM
I found this here blurb, which gives some info about the Computer-Indicator Radiac, and the wrist-watch style Thermomolumiscent Dosimeter (TLD) it is designed to read.
MIL-PRF-49293B, PERFORMANCE SPECIFICATION: RADIAC SET, AN/PDR-75 (13-SEP-2011)
This performance specification is approved for use by USACECOM, Department of the Army and is available for use by all Departments and Agencies of the Department of Defense. This performance specification covers the Radiac Set, AN/PDR-75. The AN/PDR-75 Radiac Set consists of the Computer Indicator Radiac CP-696/PDR-75 (Reader), the Carrying Case CY-8420/PDR- 75 and three power cables. The Dosimeter (DT-236/PDR-75) is used with but not a part of the Radiac Set. It measures neutrons and gammas from nuclear detonations and residual neutrons and gammas from contamination. The dosimeter is contained in a two- part case and is a type that can be worn the same as a wristwatch. The Reader is capable of opening, reading and closing the dosimeter. Two separate reading elements are contained in the Reader, consisting of an ultraviolet light source, filters and a light detector for reading the gamma dose, plus a constant current source and a peak reading voltmeter for reading the neutron dose. A digital meter displays a combined reading of the two separate reading elements. The range of the system is zero to one thousand centigrays (cGy) (threshold) and zero to two thousand cGy (objective). The CP- 696/PDR-75 is powered from a 24 volt DC source. The CP-696/PDR-75 Radiac Computer Indicator is used to measure the accumulated neutron and gamma radiation recorded by the Dosimeter DT- 236/PDR-75. The Radiac Detector DT-236/PDR-75 is worn by personnel who may be exposed to radiation from nuclear weapons.
Like most military dosimeter systems, this equipment busies itself only with death-dealing cGy and wouldn't be of any use for radiominerology, background studies or cosmic ray counting. You could always take it to pieces and re-purpose it, André, but beyond that I'd chuck it in a skip.
Sat Mar 19 2016, 03:12PM
This one has a nice axial sensor in here and also the casing is a really good beta shield.
