  • Guests: 23
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
Grrr! FEMM 4.2 analysis.
Thu Feb 25 2016, 06:33AM Print
I used to use FEMM 4.2 al the time, but I cant remember the buttons to press to get a simulation.
I can get the mesh generated, but the "sprocket" and "glasses" buttons just yell an error at me like jerks.
im missing a simple path here I just can figure it out with the wiki and pdf's that are out there.
Antonio
Thu Feb 25 2016, 02:33PM
Some error in the structure being simulated. Try something simpler.
Fri Feb 26 2016, 03:12AM
I don't think theres an error in the object. I think I just don't know what buttons to press.
Fri Feb 26 2016, 09:25PM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
"gear with hand crank" icon to solve.
"glasses" icon to display solution
What is the error?
Sat Feb 27 2016, 01:14AM
Scott Fusare wrote ...
What is the error?
those to buttons just generate an error. I think are are things before those buttons that are supposed to be done. but I don't know what the path is.
DerAlbi
Sat Feb 27 2016, 02:24AM
You are likely missing boundary conditions. Share your file.
Chris_Knight
Sat Feb 27 2016, 03:03AM
Chris_Knight Registered Member #58280 Joined: Sat Jan 09 2016, 06:48AM
Der Ali is probably right, create a large circle around your structure as a boundary condition. It's been a couple years since I've used FEMM but I think that's it.
Have you set up your solver correctly?
OK here it is in .zip file as we cant post anything else.
]electrodes.zip[/file]
DerAlbi
Sat Feb 27 2016, 10:51AM
You have no materials set and no exterior boundary.. also you have 2 points in "nowhere" with no properties.. how do you expect the solver to solve this?
Ok you have 2 conductors defined with 0V and 1V thats a start.. but how should it mesh or solve? shall it mesh to infinity or your screenboundary? wink
Look: the error you get is a perfect description of what your problem is
femm
Material properties have not
been defined for all block labels
cannot analyze the problem
OK
Soo.. first of all: define your blocks (conductors and air regions)
Then set block labels in every! block
And use usefull boundary conditions.
The solver is like a human.. you give not enough information it wont cooperate. Just think about if you were asked to draw an electrostatic field... the first thing you would cry out: "how much of it - it extents to infinity, oh i will die doing it!"
DerAlbi
Sun Feb 28 2016, 12:28PM
Here you go.
]electrodes.zip[/file] Its surely not what you want and i have set no outside boundary condition but it computes and gives you a colorfull image.
Use it as a start.
