Registered Member #2463
The Simpson 270 series multi meters made a claim as shown in the attachment.
Noticed a little finger was added to the stop pins, to touch the inner surface of the glass metallically at the bottom on one side. This finger was in contact with the meter metal pointer.
Simpson had been making meters for decades before the the 270 was introduced in ~1961.
Registered Member #834
Probably some way to avoid static electricity in the glass cover, that could attract the pointer and cause false readings. The same problem is known from compasses.
Yes the glass is what I thought. But sadly the glass is gone. Its a parts meter. I have about 10 more Simpson 260/270 meters. Logic prevents me from getting to them just now.
The issue came to life because the parts meter was used to find out the effects of a magnet needing recharging in a 270 .
When I get the other meters out, I'll try something to see if the face to back of the glass does bleed a charge.
Meters have been made for ages with that problem.
What so amazing was developed in the 1960's, to use it in their meters?
Registered Member #230
They probably used PYREX glass which is ever so slightly conductive. Pyrex is used for high voltage insulators for this slight conductivity as it distributes the charge gradient evenly --so it has a higher standoff voltage than pure insulators of the same size
Soon I hope to get at other 4 270s in the 260/270 lot. I've done stress cone work but not in glass There was another part that was in the (the parts meter) that would have gone unnoticed had the glass been there. It was a aluminum channel glued into the case that supported the glass at the bottom. Was the other purpose of this was to run a metal along that actually both touched glass faces ?
I looked into a patent long ago, for a product called Rust Evader System, that was a means of distributing a charge by a small high voltage generator, out on the painted surface of a car. This idea was to prevent water from broaching the paint, and causing rusting.
When I get my ten 200 meg resistors from Electronic Goldmine, I will start experimenting. I bought a Megger from the Orient for about $20 US and free delivery. range to 2000 megs at 2000 volts.
It does work very well. Ham radio operators discovered it, and that's how I learned.
TI has a sensor system chip that can probe fields in 3D. Small money. Later perhaps.
