  • Guests: 9
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
[moved] Where to get high voltage capacitors (10kV+)
Karmaslap
Thu Jan 28 2016, 07:14PM Print
Karmaslap Registered Member #58215 Joined: Wed Dec 30 2015, 11:27AM
A senior at my school is building a can-crusher for a project, and needs a capacitor on the magnitude of 60uF and 10kV. He is having trouble finding capacitors that fit. Does anyone have any suggestions as to how to acquire this much capacitance/voltage for the cheapest price? Good advice would be websites that sell, other places to find caps that big or smaller caps that can be added together to get fit the requirements.
He has found one for 1000$ that fits, but is hoping to find something cheaper. Any help is appreciated.
Thu Jan 28 2016, 08:23PM
Ebay and surplus stores.
Signification
Thu Jan 28 2016, 09:06PM
A soda can can get VERY crushed with only a 100uF 5kV Capacitor. And long short of $1K...
Karmaslap
Thu Jan 28 2016, 11:04PM
He's looking up that cap size, when he googled it a can crusher popped up at that exact size/voltage and impressed him. Should save him some money, thanks Signification
Signification
Fri Jan 29 2016, 02:52AM
Yeah, I just googled the same thing and saw the caps and a video of a can crusher. The guy running the crusher does NOT know how to handle high voltage!! He uses no eye/hearing protection, and puts both hands on a high energy components--looks like he assumes no voltage remains after the cap fires! A good way to die--fast!...notice that immediately after the can is crushed, he grabs the can--one hand on top and the other on bottom--INSANE! This is a great video on how NOT to handle high voltage/energy circuits.
I have heard that something like 40 Joules or less can be lethal -SOMEONE PLEASE CORRECT ME ON THIS IF IT'S DIFFERENT---A 5000V @ 100uF capacitor can store 1,250 Joules (over 30x the lethal level)!
I understand this is a high school student--Please make sure you get proper experience and instruction before doing this! These pulse capacitors actually --go-affter-you--may sound crazy, but be scared of them!! dead I have always believed that charged high voltage/energy caps are the most dangerous components. BTW: three defibrillator capacitors in parallel can be close to what you want. You need pulse rated caps.
Fri Jan 29 2016, 09:02AM
Less than 40J can be lethal too, it depends on many things, how you get shocked, voltage, current, total charge etc.
With a single shock from a capacitor you are most likely to risk heart fibrillation. A normal defibrillator used by paramedics (or the modern use by everyone and their dog) uses from a few Joules up to 360, so it surely won't kill you by guarantee.
Shocking yourself with a high voltage capacitor is however not going to end well, the energy is delivered too fast, a defibrillator has a large inductor to slow the current pulse down.
Play it safe, use NC grounding circuits at power loss, atleast 2 different charge indicators so one can fail. Only operate it through isolated mechanisms like strings, rods, air, fiber optic.
Karmaslap
Fri Jan 29 2016, 01:09PM
Signification wrote ...
There are a lot of vids like that. It gets worse, as some people trigger their circuits by grabbing an exposed wire with a glove and jamming it against another wire, making a huge spark. It's somewhere around .002 A that is lethal- it will cause arrhythmia, then a range above that is "safer" until you get to the point where the current can start cooking you.
Senior in College, actually, not high school. We have as much instruction as we'd ever formally get, so it's more about not being stupid.
We'll probably trigger with a spark gap, so isolating ourselves any time the caps are charging up won't be difficult. I don't know what backup "safe discharge" he has planned but I'll make sure there is one.
Depending on the price of the caps he'll want 2 100uF 5kV to make a 10kV cap, or maybe higher with more of them. I'll post any other questions we have here if they arise. This should probably be moved to high voltage?
Signification
Fri Jan 29 2016, 05:01PM
You know that would then knock your capacitance down to 50uF, which may be OK. You would need FOUR 100uF @ 5kV capacitors to get 100uF @ 10kV (2s2p). If over 1kJ is involved, I try to avoid "series".
Kizmo
Fri Jan 29 2016, 05:59PM
You dont need 1kJ for can crushing. 1kJ from proper pulse capacitor will tear the can in half.
Fri Jan 29 2016, 07:12PM
I'm with Signification and Kizmo in the club of people totally crushing cans, or tearing them in half, with 1 kJ or less. But capacitor voltage rating should be at least a few kV. Trying to do it with less voltage, e.g. electrolytics, will be even more horribly inefficient. For a given energy, the optimum number of coil turns goes up with V. But it can't be less than 1!
Used defibrillator capacitors are all over the place and will become more common. Definitely up to the task of can crushing, but it's hard on the capacitors unless you use more than one. Lots of posts about it 10 years ago by Peter "tesladownunder" Terren.
Mads Barnkob wrote ...
A paramedic, on his fourth day on the job, playfully zapped his co-worker as they rode in an ambulance. She died. Link2 I think modern automatic defibs will not fire unless they detect a bad heart signal. That smartness is not built into the capacitors!
