  • Guests: 9
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Function generator for tesla coil use
Dédé!
Fri Jan 22 2016, 09:46AM Print
Dédé! Registered Member #4932 Joined: Thu May 17 2012, 01:42PM
I came across this function generator on ebay and was wondering if it was a good bang for my buck or if I would be better of buying a different function generator. If so, which one should I buy? I don't want to spend much more than €100.
Fri Jan 22 2016, 11:29AM
The instrument seem to have some good features, but nothing that can not be done by hand and I really prefer dials over up/down buttons for much of my testing. But it all depends on what you are doing, which is why I got one of each :)
If it is just for testing drivers, you can easily do with a couple of 555 or TL494 timer circuits and a oscilloscope. Even for secondary testing you could add a transistor output for more output power.
I usually use a 555 timer for feedback to the driver when testing and a signal generator on the OCD input.
I got these two good old instruments.
Hewlett Packard 3310A Function generator
Hewlett Packard 3325A Synthesizer / function generator
Dédé!
Fri Jan 22 2016, 06:29PM
Thanks for your reply,
I prefer dials too. That's why I chose this specific function generator. I think I'll just buy this one and build a simple 555 circuit so I can use it until this function generator has been delivered or if I need two at the same time.
