Registered Member #162
I had a FE5680A Rb oscillator, from eBay when China was upgrading its cellular networks I checked the frequency against a gps-locked oscillator ... fraction of one Hz difference (I guestimated <1/16 Hz watching Lissajou on 'scope) Sold it to a friend at work who had a use for it.
OCXO do drift with time but older units drift more slowly so it would be worth 'tweaking' your OCXO
Registered Member #96
Cool, thanks. Do you have any tips on making some sort of calibrator that would give me a rough guide? Thought maybe lock onto the no-longer-in-Rugby signal and then derive the 1ppm frequency from this using a second oscillator with a PWM to keep it on track.
the 60 kHz MSF and 77 kHz DCF time stations have modulation that I found unsuitable for a direct frequency reference
198 kHz is usable but does have phase modulation as well as the obvious audio amplitude modulation with a little extra (TA7642 + LM386 + speaker etc.) you can listen to Radio 4 (I don't) the 500 kW at <30 km gives me a nice signal !
even gps-locked clocks aren't perfect but 1ppm ok
Although Rb clocks are excellent they have an offset from the ideal atomic frequency that drifts a little with age so not perfect but even an old one should be =/- 1 ppm
Thanks for the tips! It would be amusing to actually calibrate the thing then put a "calibrated in 2016 by Nygmatec" sticker on it..
EDIT: that chip is a 3 pin replacement for the MK484. Whats the least complicated method of making a good antenna, thought maybe use ferrite rings in series. Finally a use for those $^!£&!£ rings I have about a million of.
Registered Member #39190
I have a number of OCXOs and wanted to get a quick evaluation of their calibration and drift. Most have either 10 MHz or 12.8 MHz output. So these were passed through a flip-flop (functioning as a prescaler) to obtain a clock in the 5.0 to 6.4 MHz range. This was applied to the oscillator input of a Parallax Propeller. The 16X PLL was enabled on the Propeller, which then drives an internal 32-bit counter (as well as all eight processor cores) at 80-102.4 MHz. One of the cores of the processor is then tasked at polling the 1pps output of a GPS receiver with 50ns or better resolution. (Another core can be dedicated to this same task with a second GPS receiver, for comparison.)
It is assumed that short-term deviations will largely be the fault of the GPS, and that long term drift will always be the fault of the OCXO. In this way I've been able to track drift and error with excellent resolution over a wide range of time scales, from seconds to months.
The simplest antenna suitable for 198 kHz is a vertical whip any length of wire suspended vertically, connections to 'Earth' and the bottom of the whip. Such an antenna will probably receive a stronger signal from am broadcast transmitters than the 198 kHz so low pass (or band pass) filtering will be required
Next simplest is a multi-turn loop, 1 ft. to 1 or 2 m diameter, round, square, octagonal etc. tune the loop to 198 kHz with one or more capacitors the resonant loop will form a good band pass filter.
Finally a ferrite rod antenna, no reason why you could not use a 'roll' of stacked ferrite toroids as the core not as ideal as a solid ferrite rod but good enough. I prefer NiZn ferrite (non-conductive to a dmm) to MnZn (easily detectable conductivity using any dmm resistance range) but at 198 kHz I guess even some MnZn ferrites may work ok
I suggest the multi-turn loop, roughly speaking the important parameters are resonant frequency and Q more turns and/or larger size increases received voltage use loop in the vertical plane for LW, max response in the plane of the loop, null on-axis. Spaced turns (one to six wire diameters air space) give better Q than close turns Any copper wire will work, 0.4 to 1mm is probably 'optimum', 660/0.04 'Litz' wire would be better, but $$$
Whatever, if you want audio then a receive bandwidth of c9 kHz is required, so the 'q' required is only 198/9 = 22 whereas for a frequency reference you want the highest Q practical to reduce 'noise/breakthrough/interference'
I tried an op-amp bandpass filter to remove (severely attenuate) phase modulation, but failed.
A bang-bang frequency lock loop should work well, especially if integration times are long (>5s for 1 ppm ?)
P.S. a quote that I vaguely remember from time nuts
A man with a clock knows the time, A man with three clocks is never really sure.
P.P.S. I do not use any of the above antennas, because I receive such a strong signal I use a 6" pvc pipe with 92 turns of pvc insulated 1 mm2 multi strand tinned copper wire that I have from some long forgotten experiment, definitely not ideal but I get 0v5 rms open-circuit when tuned, which is enough for my 'scope etc.
Thanks! I'm actually trying to add a radiation sensor to a clock at the moment, the idea being that it serves as both a battery indicator and shows if something bad (tm) has occurred. See also you can make one using pyrolytic graphite and a silicon photodiode but the front contact is in fact the graphite (!)
And which I can fix trivially with "Andre's patent pending 10M+0.01uF tube series bypass circuit (tm) (c) "
