[moved] IGBT module for induction heater
Claude
Wed Jan 06 2016, 08:33AM
Registered Member #3379
Hello I have managed to aquire two IGBT halfbridge modules Fuji 2MBI200F-060. I'm thinking of using them for an induction heater operating at around 80Khz. I have looked up the specs on the turn on and turn off times but do not know how to work out if these modules are suitable. Can somebody help out. Thankyou Claude.
Registered Member #1403
As part of a DRSSTC guide I wrote a chapter on derating IGBTs when used in soft switching / ZCS, so if this is the case for your application it might be of use to you:
