  • Guests: 19
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
DRSSTC V ( now "Skinny Coil" )
Phillip Slawinski
Tue Nov 15 2016, 09:46PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Uspring wrote ...
Are you using some kind of primary current modulation such as a phase shifted bridge?
Yes; freewheeling.
KrowBar wrote ...
I have to keep up on things so I don't miss seeing these great coils in action live. What's this Teslathon you had? Was it in Huntsville? I moved to Madison not too long ago and am trying to get enough house projects finished to have time to get back into coiling. With a couple of avid coilers nearby it's a shame that I haven't been more involved in the hobby lately.
It's just a small "Teslathon" that I have every year at my home (in HSV). We run a bunch of solid state coils, drink beer, and eat good food from the BBQ.
Hydron
Tue Nov 15 2016, 10:04PM
How does the noise compare with long pulse-length to short pulse-length?
Am building a QCW as my second coil as I'm now space and noise limited, but I'd like to know if I'd also be able to run it in a more conventional square pulse type mode without getting the cops called on me!
Phillip Slawinski
Tue Nov 15 2016, 10:31PM
Hydron wrote ...
It's not quiet like a QCW, but it's not quite as loud and shrill as a low duty DRSSTC. I need hearing protection when I run it inside.
Hydron
Wed Nov 16 2016, 08:37AM
Thanks, that's good to know.
On another note I've sketched up a draft schematic for a mod to the UD2.x to allow freewheeling, will post it in another thread for review.
Kizmo requested it and will probably give it a go, but I welcome any comments etc on the inevitable mistakes I've made.
Hopefully if it works then others can have a go with higher duty cycle coils.
Edit: see thread here: Link2
Phillip Slawinski
Sun Nov 20 2016, 09:45PM
I finally got ahold of some more video form the event.
And some photos... thanks to John Forcina for both.
30334428223 77d5390814 Z
~2.4m!
30334427973 E8beabf813 Z
31141573305 06d0d576b6 Z
Intra
Thu Oct 11 2018, 04:41PM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
How much cycles of startup oscillator this coil have?
Phillip Slawinski
Fri Oct 12 2018, 01:50AM
Intra wrote ...
Two. The coil runs at F0, so probably it would be okay with just one startup cycle.
Intra
Fri Oct 12 2018, 08:37AM
Phillip Slawinski wrote ...
Intra wrote ...
Why then startup oscillator is needed if coil runs at lower pole?
I thought startup oscillator was created for holding coil startup at higher pole when primary tuned on lower until streamer capacitance will not drop resonant frequency.
Phillip Slawinski
Fri Oct 12 2018, 11:22PM
Intra wrote ...
The startup oscillator can be used to force a coil to oscillate at the upper pole, but it's also used to just get the coil oscillating in the first place. It also ensures that the switching isn't 'wrong' on the first half cycle like you get with inductor phase lead drivers.
