  • Guests: 19
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
STRANGE EFFECT...
Slava
Sat Nov 14 2015, 04:57PM Print
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
Why does this work? I would understand if the coils were aligned, but here they are side by side...
Signification
Sat Nov 14 2015, 05:03PM
Looks like you are not escaping Lenz's law here. The coils are close each with alternating "N" and "S". There is some "looping" delta B coupling--your mutual induction (between each coil) is not zero.
Slava
Sat Nov 14 2015, 05:08PM
How can near field induction light an LED like that? Maybe it's RF ?
TOP: 9"
SIDE: 5"
Signification
Sat Nov 14 2015, 05:16PM
35kHz IS RF "+" is you just stare cockeyed at an LED like that it will light!
Slava
Sat Nov 14 2015, 05:22PM
I didn't know that the impedance of a coil matches free space so well...
BigBad
Sat Nov 14 2015, 05:47PM
It can do, but in this case, it's probably not free space, it's not radio waves, it's near field stuff, well within a quarter wavelength, it's just inductively coupled magnetic fields: simple Faraday's law.
What frequency/wavelength were you driving it with?
Slava
Sat Nov 14 2015, 05:49PM
I thought that coils have to be aligned for induction to occur? Polarization...
BigBad
Sat Nov 14 2015, 05:54PM
The field lines come out of the centre of the source coil and some of them curve down into the receiver coil. The current will be flowing in opposite directions in the coils in this configuration.
The general principle is that the receiver coil's axis has to be aligned with the transmitter's field lines to generate maximum power. You can also get the coils at 90 degrees to each other in some configurations.
Slava
Sat Nov 14 2015, 06:13PM
This sucks.. I have to do 21 experiments per capacitor. Is there any better way to optimize?
BigBad
Sat Nov 14 2015, 06:17PM
What experiments?
