  • Guests: 17
06/02 GreySoul (45)
06/02 GluD (35)
06/02 northern_lightning (41)
Little Jacob's ladder
Patric
Thu Nov 12 2015, 04:16PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
It works (with Mazzilli driver)! I like to use this circuit for a little Tesla coil, but I (still) do not know if it will work. Any suggestions?
Signification
Thu Nov 12 2015, 04:55PM
I found that if you use --very-- thin gauge wire, even less than 30AWG (like flexible thread), you can precisely adjust a slight straight slope for very long wire lengths by pulling the wires UPWARD by their tops. I have even gone from NST-on-floor to wire-at-ceiling with easily adjustable gap--the main trick is that the wires don't hold a -bend- It's texture is actually thread-like. Make sure the narrow gap is the lower gap and that the the wires rise straight up--gravity!!!
What are the specs of that transformer (mA and kV)?
Patric
Thu Nov 12 2015, 05:01PM
The transformer is 12V 5A.
Thu Nov 12 2015, 07:04PM
that is the most amazing 12 V @ 5 A arc that I've ever seen ! wink
for less than perfectly straight metal wires,
if you clamp one end and pull the other (thicker wires will need leverage)
when the wire stretches just a little, less than 1% elongation, stop pulling.
The wire will be amazingly straight !
tinned or enamelled copper wire work well,
the tiny % elongation does not seem to damage the insulation.
good enough for my uses.
Patric
Thu Nov 12 2015, 07:46PM
Thanks. The two 'wires' are little iron tubes from an old lamp. smile
Signification
Thu Nov 12 2015, 08:49PM
you need to look for a LOT higher voltage and a LOT lower current--usually it's somewhere on the transformer with the ladder leads attached. I don't know where you are getting 12V @ 5A but it is NOT from the spark source transformer, and it's too big for a solid state module--in agreement with Sulaiman, and accounting scaling, that's the best JL arc I have seen.
Patric
Fri Nov 13 2015, 05:54PM
I do not understand everything... To make it clear, here is a picture of the giblets:
1447437234 2899 FT173880 Jaco
hen918
Sat Nov 14 2015, 10:45AM
Quite a nice setup, you have a mains transformer (a 12V one, I am assuming) rectified and smoothed powering a Mazzilli driver attached to a flyback transformer. Looking at the number of turns your output will probably be about 20kV at 5-10mA
Patric
Sat Nov 14 2015, 03:52PM
Yes. smile
Signification
Sat Nov 14 2015, 04:51PM
...never seen one like that before--like an NST with NO POTTING, great!
