  • Guests: 33
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
200W to 2000W induction hob £29.99 @ Maplin
Tue Sept 08 2015, 12:38PM Print
this may interest some in UK, probably similar or better elsewhere,
So cheap someone may be tempted to use it as the primary of an sstc.
done before by others, but now cheap !
Dr. Slack
Tue Sept 08 2015, 02:37PM
Anybody know what frequency do they tend to run at? They don't specify it, and I can't imagine that posting a question on their site will lead to much illumination.
Wed Sept 09 2015, 08:38AM
The only reference that I found after a quick online search ... 20 - 100 kHz
May also be of interest for wireless charging experiments etc.
(do not stuff 2 kW up your smartphone !)
Ash Small
Wed Sept 09 2015, 09:59AM
Sulaiman wrote ...
That would certainly make sense if these use IGBT's. Presumably frequency drops when 'loaded', and rises under no load?
Wed Sept 09 2015, 12:56PM
£29 for an induction hob makes it useful for all sorts of applications, notably microwave/induction hybrids.
Just use a microwave with a porous Al base and a solid metal casing behind that for safety...
Wolfram
Wed Sept 09 2015, 01:49PM
Dr. Slack wrote ...
The ones I've seen usually run at between 20 and 30 kHz. The cheap ones like this usually use a single transistor topology, with a parallel resonant tank. For the transistor, they commonly use a single 1200 V IGBT. It's a bit sketchy but it works. The more expensive ones often use an IGBT half-bridge driving a series resonant tank circuit. This appnote from Fairchild gives a nice overview of the topologies Link2 .
Sat Sept 12 2015, 01:12PM
Might make quite a nice "tank" driver for ultrasonics.
Cristian
Mon May 22 2017, 12:20AM
Cristian Registered Member #61486 Joined: Mon Feb 20 2017, 01:09AM
this can be useful, it's a analysis of a 1.8 kw induction heater hotplate
And this is the teardown of the same hotplate
Sch All Wm
Tue Jun 20 2017, 07:37PM
What happens if you "stuff 2KW up your smartphone"? Sounds like someone has to have tried this, just for the heck of it.
