PSpice model for a CM600HA24
Blackcurrant
Mon Sept 07 2015, 01:14PM
Registered Member #2989
Hi, I'm looking for a Pspice model for a CM600HA24 the two I have do not simulate anything like the datasheet. As I know a few Tesla coil builders here have used this part and thrashed the living daylights out of it I thought I would ask here first before trying to reinvent the wheel. I've been searching on google for a while but could only find two spice models that don't really work. So if anybody has a model for this part please could you post it here. Thanks
I'm trying to simulate one high current pulse but these models don't seem to have an accurate C to E saturation voltage? here's the two I have
* Created using Parts release 6.3 on 12/08/95 at 17:38 .MODEL CM600HA-24H NIGBT + TAU=338.37E-9 + KP=77.504 + AREA=700.00E-6 + BVF=2 + AGD=150.00E-6 + WB=117.00E-6 + VT=6.8805 + KF=6.3537 + CGS=14.678E-9 + COXD=44.520E-9 + VTD=-8.1640
*SRC=CM600HA24;CM600HA24;IGBTs;w/
Diode;Powerex 1200V 600A *SYM=IGBT .SUBCKT CM600HA24 71 72 74 * TERMINALS: C G E Q1 83 81 85 QOUT; OFF M1 81 82 83 83 MFIN L=1U W=1U DSD 83 81 DO DBE 85 81 DE RC 85 71 1.01M RE 83 73 101U RG 72 82 0.25 CGE 82 83 68.4N EGD 91 0 82 81 1 VFB 93 0 0 FFB 82 81 VFB 1 CGD 92 93 272N R1 92 0 1 D1 91 92 DLIM DHV 94 93 DR R2 91 94 1 D2 94 0 DLIM LE 73 74 7.5N DLV 94 95 DR 13 RLV 95 0 1 ESD 96 93 POLY(1) 83 81 19 1 MLV 95 96 93 93 SW DFW 74 71 CM600HA2 .MODEL CM600HA2 D (IS=853N RS=70U N=1.7 BV=1.2K IBV=10U + CJO=24.7N VJ=0.75 M=0.333 TT=360N) .MODEL SW NMOS (LEVEL=3 VTO=0 KP=5) .MODEL QOUT PNP (IS=15P NF=1.2 BF=5.1 CJE=351N TF=94.4N XTB=1.3) .MODEL MFIN NMOS (LEVEL=3 VMAX=705K THETA=40M ETA=1M VTO=6 KP=28.9) .MODEL DR D (IS=1.5P CJO=19.4N VJ=1 M=0.82) .MODEL DO D (IS=1.5P BV=1.2K CJO=79.2N VJ=1 M=0.7) .MODEL DE D (IS=1.5P BV=15 N=2) .MODEL DLIM D (IS=100N) .ENDS **********
