  • Guests: 24
wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
05/09 AmonRa (44)
Doing away with hardware MIDI interrupters
Adam Munich
Mon Jul 20 2015, 07:45PM Print
Hi all,
After having quite a frustrating time trying to run 8 synchronized timers on a micro controller unsuited for the task, I thought of a better way to play MIDI files into a DRSSTC.
Inside this ZIP file is a SoundFont file and a player; just drop the SF2 into the player, select your favorite MIDI file and out of your sound card, will come nice square pulses that can be buffered and sent over a fiber link.
1437421453 2893 FT0 Pulse
Cheers,
-Adam
Goodchild
Mon Jul 20 2015, 08:22PM
Adam,
I like the idea, my only dread is the lack of control over the PC sound card, if the OS decided to steal the card or the driver crashed you could be potentially left with some long pulses that can cause damage, are you mitigating that in any way? Potentially a micro with priority control over the fiber output being fed from a USB codec could solve that problem, but then again I'm paranoid....
Great work, I would not have guessed that an audio codec could resolve <50uS pules seeing that it's approaching it upper bandwidth usually around 20KHz.
Adam Munich
Fri Jul 24 2015, 05:19PM
The sound card does sample at 44,100 Hz, so I figured if I were to create a waveform with 10 "high" samples and 90 low samples, I'd get a ~440Hz waveform to play with. Adding a few bits here and there and concatenating several samples gave me a true 440Hz wavfile to play with.
SoundFonts are played at different pitches through resampling, so the ~120us pulse width for 440 becomes shorter for higher frequencies, and greater for lower ones. The idea is your "buffer" would be a schmitt-triggered adjustable one-shot which pays attention to only the rising edges.
I have not yet built that, but will have more space to screw about with my tesla coil when I move from berkeley to atherton in a month or so.
Cheers,
-Adam
nzoomed
Sat Jul 25 2015, 02:14AM
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
Is it possible to have software that can generate MIDI output from taking the peaks and notes of the waveform of any music being played and convert it to a signal that would play on the tesla coil?
This would be far easier than getting midi files and trying to synchronise them to a backing track.
fatboyslim
Wed Sept 30 2020, 07:48AM
fatboyslim Registered Member #1779 Joined: Sat Oct 25 2008, 11:05AM
Are you able to repost the sf2 link? This is the solution to my midi problems I have been searching for.
