Registered Member #2431
Id like you all to use a "sane-o-meter" to check my idea.
looking here : and
And researching some previous work by others. I need to be able to switch HV from a single location (source) to many different locations (sinks) at differing times. At the 10 to 20 Kv level.
Ive seen some work by power companies using long towers of bricks with toriods for field grading. I may not need all that, but id like 100uS rise and fall times (could be slower).
so is this possible practically or am i crazy, or should i just have an array of transformers driven by a microprocessor ?
It should be possible to stack them. They like to fail short, so any issue may result in cascading failure of the entire stack. (and possibly high voltage through your delicate control circuitry?)
Registered Member #816
The thing I don't like about the source coupled stacks, is all the fets turn on and off sequentially, the bottom one is the only one driven directly.
Personally I would do it with a large toriod gate transformer with multiple secondary's (1 per fet) wound with the thinnest hv wire that will fit. Usual passive components back to back zenners e.c.t on the gates, and some form of static voltage balancing, resistors across each drain source or a few Tvs diodes in series instead.
Assuming your drive wave shape and frequency can go through a transformer that is, else you are going to need more complex secondary side driver circuitry.
I was thinking, about a special ferite toroid specifically engineered for high voltage multiple secondaries. i guess a toroid is the best shape.
then, some complicated support components on each gate. TVS's, rise and fall diodes and what not. im deciding on mosfets or igbts at the moment. not sure what the current average or peak is yet, for my time intervals.
Registered Member #162
I have serviced equipment with about 20 mosfets in series, each mosfet had a ferrite toroid with gate winding (secondaries) and a single well insulated wire passed through all toroids (primaries) this gives voltage insulation and each mosfet gets the same voltage vs. time waveform
equivalent to having N single turn primary GDTs in series, so you could prototype just one stage using a single turn primary of course high permeability ferrite toroid cores are required as for any GDT the longer the required ON time the greater the number of secondary turns required Integral(e.dt) = integral(Vgate.dt/turns) = saturation limit of core. (e = volts/turn)
I dont want anything crazy strict. like 1nS on/off times. Or 100 billion volt / second changes.
So, lets start with 20uS rise, 20uS fall and 100 or more duration high uS.
im starting to think 15 kV maybe to lowest i can go. but im looking for the lowest cost mosfets, like in the 2kV range. the 4kv ones really jump in cost. and if i blow a few the cost will be a problem.
so if i down rate the system by 20% that will mean 15kV x 1.2 = 18kV for each leg.
