According to this, the specs are: Wavelength- 1034nm Pulse Energy - .1J Repetition Rate 50Hz Pulse Duration 10^5nS Beam Diameter 5mm
The given measurements for the control module and the laser module are exactly what this site says they should be. It does have a 220V plug on it, and the laser diode is water cooled. So, not having the pictures or any other information I can find I'm assuming they are the same laser unit. The unit does not have any other markings than what you see on the front.
I know very little about lasers. Am I right in thinking its about a 5W YAG laser in the IR band? What protective measures do you suggest? If I buy OD7+ protective eyewear will that protect my eyes?
Lastly, do I have any business playing with this or do I just need to sell it?
Registered Member #56
That is a nice little self contained laser, it is at least worth a try to see if it fires up.
You will want to fill up the water loop (drain whatever might currently be in there out) and make sure that it is correctly circulating before trying to fire it.
Also, the 1034nm wavelength sounds to me more like Yb:YAG than Nd:YAG (not that it really matters), and that particular laser has an interesting cavity geometry with what appears to be 3 passes through a slab shaped gain medium. This was probably related to the very long pulse duration (0.1s). Definitely in the IR, OD7 goggles rated to cover 1034nm will definitely work (just about any yag goggles will cover this band).
As to possible uses, it puts out a sizable peak power (100W) which will be able to burn through thin metal and whatnot.
ps - pretty sure that laser is actually flashlamp pumped, so there are no laser didoes in it.
