  • Guests: 21
Finn Hammer (72)
Blue Adept (43)
Nickel (68)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Wanted in UK: four pole double throw switch.
Ash Small
Fri Jun 26 2015, 11:39AM Print
Does anyone have a 'spare' four pole double throw switch, rated at several amps at 250V (15 or 20 would be ideal, but ten might be ok).
A 'decent quality' one will cost me over £50 new, from RS or direct from the states (even Farnell only stocks them in US)
I can get a 'cheap' one, but in my experience, the cheap ones tend to just 'fall apart', and the cheap ones only seem to be rated for 16A@125V anyway.
The switch needs to be the 'ON-OFF-ON' type.
Thanks.
EDIT: The alternative is to use four double pole relays, if anyone has any going spare. Again, 250V, at least 10A.
Dr. Slack
Fri Jun 26 2015, 01:22PM
I can't help you with the switch, but I do have a shed-load of Omron MK3P 3 pole relays ]omron_mk3p.pdf[/file] They are 24VDC coils (56mA, 430ohm), which should not be too bad to create from mains, might even be an advantage to bring out a low voltage control? The carrying rating is only 10A at 250v, electrical life of 100k switching operations at 250V 1750VA inductive load.
Ash Small
Fri Jun 26 2015, 01:31PM
Sounds interesting. It's for a 0.25HP motor, 2.3A continuous.
I think it's four double pole relays, in order to provide sufficient isolation, etc.
Because it's a motor I figure I need higher rated relays than 3A.
I was thinking of incorporating either 12V or 24V transformer for low voltage lighting/submersible coolant pump, so 24V won't be an issue.
The coolant pump will require a rectified supply, and it probably makes sense to smooth it as well. I have a spare 24V battery charger which should be ideal.
EDIT: found these four pole double throw relays from RS. I'd need two, which at that price isn't bad. Link2
Just noticed the four pole ones are only rated for 5A.
