  • Guests: 26
kg7bz (68)
steve516 (31)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
New 900V SiC MOSFET launched by Cree, 11.5nS switching time
Ash Small
Thu May 14 2015, 12:35AM Print
]c3m0065090j.pdf[/file]
Launched yesterday, from what I can gather. No-one has them in stock yet, so don't know the price.
This could be what I've been waiting for. Pulsed current of 90A, 900V and ~10nS switching times.
Can't wait to see the price.
hen918
Thu May 14 2015, 07:09PM
Looks like the ultimate MOSFET. Package looks a bit weird though, although it should be more efficient at high powers, you would have thought the 7L D2PAK would be better suited to lower voltage, higher current applications, where the package is often the limiting factor.
Thu May 14 2015, 07:45PM
This is a great package and transistor, i finnally have a "DS" that comes off the die, instead of a dam PCB trace with incudtance+Vdrop+current switchng time. now the driving IC can actually see real measurements.
Ash Small
Thu May 14 2015, 09:08PM
Let's see what the price is first. Last time I saw anything similar thay were £40 each from Farnell.
The speed of these is amazing considering the voltage and current capability. Heating must be a problem, hence the wierd package, I presume.
Now we just have to wait and see who has them on the website first, and the all important question.....the price.
Adrenaline
Fri May 22 2015, 06:19PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
Not too bad:
Digikey
has them for 10.31USD
They do have it in TO-247 too:
http://www.cree.com/~/media/Files/Cree/Power/Data%20Sheets/C3M0065090D.pdf
looks like 9.98USD from Digikey
http://www.digikey.com/product-detail/en/C3M0065090D/C3M0065090D-ND/5253283
Fri May 22 2015, 08:15PM
For c.r.t. T.V./Monitor type flyback I'm considering this 1700V SiC mosfet Link2
not quite as fast but very useful......
(I'm not really converted to surface mount yet)
Ash Small
Tue May 26 2015, 01:00PM
Mouser has them in stock in UK for £7.21
This is about one sixth the price of the previous generation ones I was looking at, although the others had a slightly better voltage rating and was slightly faster.
These should still be plenty fast enough for what I have in mind, though. Anyone else who has been thinking about the 'inductive adder pulse generator' circuits that were being discussed here a while back should take a look at these as well wink
Tue May 26 2015, 07:19PM
A small but maybe important thing I noticed,
the SiC mosfet reverse gate voltages are much lower than the forward voltage,
some designs may have problems with this.
Wed May 27 2015, 06:12AM
Sulaiman wrote ...
VGSmax Gate - Source Voltage -8/+18 V (Absolute maximum values)
Yes, most driver circuits will have to be changed, preferably to a modern mosfet driver ic that can do those exact voltages, atleast the lower turn off voltage. Like: Link2
Ash Small
Wed May 27 2015, 11:38AM
Sulaiman wrote ...
It doesn't mention anything in the datasheet. (link in OP)
I presume you are referring to reverse voltage spikes when used in flyback topology.
This is exactly what I was planning on using them for. Are you not also considering using SIC's for flybacks?
It does mention something about not exceeding -4 volts between gate and source if using the integral freewheeling diode.
Mads Barnkob wrote ...
I presume you'd need to use the maximum voltages in order to achieve the published switching times. Does this mean blocking the integral freewheeling diode and adding an external Shottky, or something?
