[moved] Physics HV Poem
Slava
Wed Mar 18 2015, 05:46PM
Registered Member #518
Here is a poem I wrote some time ago and publish in Wired Magazine....
Analog circuits come easy to me. It's easy to see that electrons are easy to free Using high eV UV Electron clouds will form almost instantly. If you apply HV to the hot cathode, and speed of light C is the upper bound Then V of electron E approaches infinity much higher than speed of sound When it hits the common ground Given that there is low pressure and humidity But I'll be humble to preserve humility. Cause we don't want heat losses in current flows and social blows due to turbidity.
