  • Guests: 33
BlakFyre (36)
SENTRY (31)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
large coil gun
1 2 3 4  last
Fri Feb 20 2015, 09:20PM Print
Is anyone aware of the largest home-built coil gun on this or another forum? I've seen small ones that shoot small pieces of metal across a room. I'm curious if anyone has built one that can cause serious damage.
(I'm not talking about the Navy's)
DerAlbi
Sat Feb 21 2015, 02:06AM
i am on the way to 100J Projectile energy. but it will take some time.
Signification
Sat Feb 21 2015, 02:26AM
Do you have, in mind, a particular projectile mass and efficiency at 100J ?
DerAlbi
Sat Feb 21 2015, 03:44AM
exit velocity will be 100m/s. but its not the time for details right now.
Sat Feb 21 2015, 09:16AM
IamSmooth wrote ...
The first shot from my first coil gun nearly killed my son,
he almost died laughing at how pathetically weak it was !
DerAlbi
Sat Feb 21 2015, 01:31PM
Yeah, true... the easy CG-Designs just suck. Also on Youtube.. if you watch Jason Murray (most successfull coilgunner on youtube i guess), the views are only driven by the appearance.. not technical data or capability.
Shooting at stuff that breaks easily anyway makes a good video.. but anyone with a brain knows how pathetic it actually is.
However he got 25J which is not too bad at all.
hen918
Sat Feb 21 2015, 02:58PM
I have eight 3300uf, 400v capacitors and intend to make a 1200v 2200uf bank out of 6 of them, but the large size of the bank makes a coilgun somewhat impractical.
Signification
Sat Feb 21 2015, 03:48PM
hen918, I would go for it--I don't think 1200v will be problematic--but I assume that is not your worry. I have a batch of electrolytics: 10,000uF 450v (525V surge with heavy duty terminals) and was thinking of doing that three-in-seies type configurations with 1200v to 1450v. Mainly I am curious about coilguns with higher voltage electrolytic banks energizing magnet wire coils. I also have some 6800uF and 6200uF @ 450vdc.
Have you ever known of energy storage caps (or any other than 'lytics) used in coilguns?
DerAlbi
Sat Feb 21 2015, 03:55PM
May i ask why somwething else would be desireable? You can use big foil caps of course. but why would you...
Caps (electrolytics) are not the limiting factor.
There was one guy here who used nonpolar caps and got highest efficiency figues (20% ?) ever seen in this forum at room temperature. But this was due to a novel design and creativity. He called every SCR-based design as "monkey-design" which raged everyone red hot cheesey . but well... he was just right.
dexter
Sat Feb 21 2015, 06:35PM
DerAlbi wrote ...
what did he used?
1 2 3 4  last
