Registered Member #11591
As DerAlbi says a railgun with aluminium (on its) rails would be a one shot device. Tungsten is a good material for high temperatures / wear but you would still get deposits off of the steel projectile.
Shrad, If you use conductive powder / lubricant you risk shorting the rails out and it arcing over.
EDIT: oh, and the Lorenz forces are going to try and force the rails apart, so if they aren't completely rigid energy is going to be wasted that way. EDIT2: The projectile will have to be moving when it hits the rails. Theoretically it is possible to do it stationary, however it is very difficult to do it that way practically.
Registered Member #3414
Two steel rings (or other suitable metal) held close to each other and a mechanism for moving the rings apart for projectile release.
Only drawback is timing the release, so you can control direction, but if the mechanism is surrounded by a spiral of one turn (if that makes sense), you have directional control as well.
BigBad wrote ...
The tricky bit with a spiral like that is that if it releases at the wrong moment the ballbearing will go slamming into the start of the spiral.
I realise this. Some form of 'timing mechanism' is required. The 'separation mechanism' needs to be triggered at a point that aviods this. The exact detail of the timing mechanism will depend upon the properties of the rest of the system.
Registered Member #2099
Ash Small wrote ... Only drawback is timing the release, so you can control direction, but if the mechanism is surrounded by a spiral of one turn (if that makes sense), you have directional control as well.
If the track is a finite helix instead of a circle, there's a place for injecting the projectile and a place for letting it fly away. As with any very long railgun, you need to worry about voltage drop in the rails.
Correct me if I'm wrong, but the electromagnetic propulsion depends on the rails carrying current _behind_ the projectile and no current ahead of the projectile. A circular rail (for benchtop "spinner" experiments) needs at least one electrical gap next to a power connection. That will define the direction of rotation.
That's in contrast with the classic "ball bearing motor" trick. I can attest that those run in whichever direction you choose to start them. Fun thing to do with a low-voltage rewound MOT, when you get tired of abusing nails and small wires.
Registered Member #3215
voltage drop in the rails could be addressed with multiple parallel connections to several parts of the path, no?
for the release mechanism, a sensor at an interval x+k of the release point and another one at an interval x of the first sensor, a simple timing circuit repeating the timing between sensor 1 and sensor 2 triggered by sensor 2, and a modifier k for setting delay in mechanical device used for releasing the projectile
Shrad, I think you're missing the point of my second paragraph (in prev. post), or I am wrong.
Let's start with a conductive bridge (or sliding wire, in the EM textbooks) carrying current between two rails, and a current source connected to one end of the rails. There's an EM force tending to push the bridge away from the current source, increasing the rectangular loop's area and inductance.
Suppose the rails are powered from both ends. What defines the partition of bridge current between the two sources? Relative resistance of the rail sections? If the currents match then there's no propulsive force. I think it makes no difference if the bridge is moving to begin with.
Place a gap in the rings, so the projectile repeatedly starts at the beginning.
If only one side of the rings 'opens up', this gives us a lot more directional control, but some timing mechanism would still probably be required. If the projectile breaks a light beam it tells where it is, and the time taken to circle, which gives us it's speed.
