  • Guests: 33
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
Submarine engine
Andy
Mon Jan 05 2015, 08:51AM Print
I think have have done enought thoery on the engine, im just starting to build it, the first stage is build a hv cap, second is get the magntics and make the u shaped housen.
The engine is a side path for a submarine that I plan on building, will update the post with more of the theroy docs.
The engine is powered by a electric current throught salt water, with magntics to convert the water to velocity, and then turn a turbine.
Some pics
1420447890 4266 FT0 Img 20150105 214256
1420447890 4266 FT0 Img 20150105 214335
1420447890 4266 FT0 Img 20150105 214418
Mon Jan 05 2015, 09:10AM
What is the purpose of the turbine/propeller?
Wouldn't it be better to use a 'normal' Magnetohydrodynamic drive arrangement? Link2
Andy
Mon Jan 05 2015, 09:21AM
Hi Suliaman
The pressure of the exhust is so low compared to the surronds that it would be massivly ineffecient.
A 30J pulse in 1uS should create enought hydrogen and oxygen to fill a space 1*4*50cm tube in that pulse, if most of it is gas copared to 15psi per ten meter depth.
Andy
Wed Jan 07 2015, 06:48AM
Would this design work, using just the jet. Trying to make a really smale pipe and accerlate it up fast, the get the surronds to speed up as this goes throught it, thoughs.
1420613303 4266 FT168110 Img 20150107 194553
Andy
Thu Jan 08 2015, 11:33PM
Got a protype up and running, tryed 24 @ 48 volt with a 10 ohm resistor, the velocity would have workedout to about 1 m /1 min
1420760035 4266 FT168110 Img 20150109 121653
1420760035 4266 FT168110 Img 20150109 122818
Andy
Fri Jan 09 2015, 10:03PM
Running the thing with a car battery charger, added two more mags, the velocity is about one meter in ten seconds.
Below is a module that I think will build, just got to double check some stuff.
1420840992 4266 FT168110 Img 20150110 110051
1420840992 4266 FT168110 Img 20150110 110008
Fri Jan 09 2015, 10:45PM
I'd expect some 'leakage' current to/through the magnets
(outer terminal | fluid | magnet | fluid | inner terminal )
electrical current flowing along magnetic field lines does no work,
try insulating the magnets from the liquid,
may be more efficient.
Andy
Sat Jan 10 2015, 03:03AM
Thanks Sulaiman, tryed to insulate the mags, but made less, im guessing the current sleed across the top, make it 90 degree angles.
Also tryed useing Ti instead of steel, moving the plates closer made more speed.
Im guessing the design is floured, should have the mags in close proxmity to make the path short, and maybe Al and Ti plates as that with both seems to increase the power.
Plan B, following a more well know design
This is the setup from above
2
This is the second design, It has 4 mags point down then Mild steel directs the field to the left and the other 4 mags point it up.
1420927846 4266 FT1630 Img 20150111 110958
[Edit: Merged triple post]
Andy
Sun Jan 11 2015, 05:27PM
Tested using more reactive platrs, the source is still a 12v,2amp battery charge, next test will be trying to increase the source power
Messured the resistance of the device and are getting 14.5ohms
Below is a 24volt 2amp source
Below is a 36 volt 2 amp source
Below is a 60. 4.5. Volt. Amp throw device, with a 30uF smoothing cap for the ac recifered parts, the resisance of the mhd drive is 14.5 ohms messured by a voltage dividerr. ,R2=10ohm, vin= 12 vout=4.90
Andy
Sat Jan 24 2015, 07:53AM
Been spending sometime work out a way to get high volts with a high frequency, trying to find a way that will injuice large current throught the water as that has reached a bottle neck.
The below circuit is driven from main voltage and frequncy, with a h bridge setup to slice the ac up.
For isolation between stages are 30kv 100nf cap network on both plus and minus.
The zeners are rated for 10 volt, the transfomers are pulse types with the values taken from the datasheet, one is 50hz 0.8ohm the other 60khz at 80mohm.
The parts for this are quite cheap to muck around building it, in a while should have a prototype built and tested.
If anything is wrong with the circuit, wouldn,t mind feedback.
1422086016 4266 FT168110 Allmostthere
