  • Guests: 41
kg7bz (68)
steve516 (31)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
What to design?
Chris Cristini
Fri Nov 21 2014, 02:59AM Print
Once I get my solidworks computer up and running again in a few days what would you like me to design? If it is in a field of study I have not learned yet I will take the time to research the subject. This could also be a place where others who use CAD can also help and be a foundation of something great. I can send the solidworks files to who requested the design in the first place and no one elts with out permission. This could be a place to share pictures of the design at your own risk.
Tue Nov 25 2014, 08:18AM
22 Ghz EMDrive?
Trying to make one of these at the moment. the problem is everything has to be a lot smaller due to the shorter wavelength.
Chris Cristini
Tue Nov 25 2014, 01:39PM
Are you sure designing that would be usefull for you? Sounds like NASA stuff.
Tue Nov 25 2014, 06:01PM
How about going and designing your own 6 axis robot arm? That could be fun! :)
Chris Cristini
Mon Jan 26 2015, 02:00PM
What do you all think of this Drone idea?
Mon Jan 26 2015, 03:13PM
I am definitely NOT expert in this area but others may clarify;
for photography, vibration is a bad thing
and I suspect that the air turbulence caused by one prop above another would cause vibration
also I think that it is generally accepted that efficient lift requires lower air speed with larger prop area,
and laminar airflow,
mounting one prop above another gives high speed turbulent airflow.
Chris Cristini
Wed Jan 28 2015, 02:20PM
Here is another idea I had using 2 90mm EDF's for level Fast Forward Flight.
And a strange spaceship I designed in Auto desk Maya for a game I am working on for fun.
1422454783 1749 FT167457 Pic1
1422454783 1749 FT167457 Render1
1422454783 1749 FT167457 Pic3
1422454783 1749 FT167457 Pic2
1422454783 1749 FT167457 Gfchgv
1422454783 1749 FT167457 Mshdfas
Andy
Thu Jan 29 2015, 07:12AM
High Chris would you beable to Cad this with the option of blowing up the induval parts.
Cheers
1422515529 4266 FT167457 Img 20150129 201127
Andy
Thu Jan 29 2015, 07:34AM
Ill make a deal Chris, if you design it andake it look like it can go in a brochere I will send these free of charge
1422516862 4266 FT167457 Img 20150129 203327
Kolas
Thu Jan 29 2015, 07:41AM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
How about designing two concentric spherical conductive grids.
What I mean is spherical wire frames. They would Need to have as small a surface area as possible while maintaining structural integrity. the smaller grid should be about half the diameter of the larger grid. Meanwhile a way to keep them perfectly concentric would be necessary. This would be for a demonstration or functional IEC fusor.
