  • Guests: 16
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
The "Fat Coil" QCW Tesla Coil
first  2 3 4 5
Wed Nov 25 2015, 04:01AM
I see the snubber circuit is still in question. I have in fact abandoned the active snubber after it failed, quite violently, earlier this year. I'm uncertain whether it was a rouge spark hitting the snubber electronics that triggered the failure, or if i messed up the circuit when "improving" its wiring and mounting to the coil frame (i didnt bench test after re-wiring, maybe i goofed up). Now i've implemented a very simple passive snubber that uses a resistor and TVS diode bank. The schematics should make it pretty clear, i hope.
1448424092 146 FT167363 Fatcoilsnubbers
Intra
Mon Nov 30 2015, 08:18AM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
Steve Ward wrote ...
Wow! Thank you very much, Steve!
Toasty
Sun Jan 17 2016, 05:47PM
Toasty Registered Member #56785 Joined: Fri Aug 28 2015, 02:54PM
BSVi wrote ...
Why don't you just shut down buck in overcurrent condition and let groundstrike consume ~40 J of energy that is left in LC filter?
I dont think that could harm bridge. From my experementation, such an long streamer has considerable impedance and primary current rises by only ~100А. So I think it's safe to disable buck and let system rampdown by itself.
Thats, at least, what i did in my coil:
1416549797 1637 FT167363 Bang
wow that coil is insane!
first  2 3 4 5
