Registered Member #61
We've all had projects that didn't go quite the way we planned. Usually failures aren't so bad to recover from, but sometimes, you really lose hard. This thread is about the latter.
I'll start: I had scrounged some CCFL inverters, and I was pulling arcs from them. They worked decently individually, but performance wasn't really great. I had gotten onto the idea of seriesing them (or paralleling them) for arcs longer than 2cm or so.
For those of you unfamiliar with the circuit, you can take a look at the schematic (sketched on a napkin, then eaglized -- I might've gotten something wrong, but it's about accurate, IIRC). That schematic shows the configuration if you want to run them in series. Particularly interesting is that the feedback windings are all tied together to keep all of the inverters in phase; else, you'd just end up with a mess with similar (or less) power. Also interesting is what appears to be a ballast on the output to avoid destruction in the case of exactly what I was doing.
Well, I decided that there was no need for all three of them in circuit -- I wanted the most power that I could get! So, I dutifully removed two and replaced them with short circuits. I powered it up, and drew an absolutely beautiful arc -- the most powerful I'd ever had from it. Had a nice white tone in the middle, and was probably .5cm thick. Dead silent. But as I was playing, the arc suddenly extinguished. I reached for my battery to jiggle the terminals -- sometimes the wires tended to fall off the top of the 7Ah SLA's connectors. As I reached, I heard a *click!*.
I knew instinctively what the click was; it was the sound of my ammeter's needle pegging. I looked over, and confirmedit. I tried one more time to strike an arc, and I noticed that there was no way in hell that the arc was going to strike. One of the transistors on one of the boards had quite nicely melted, and the others were about to go.
Evidently, that one little ballast couldn't handle the HV across it -- or, more correctly, the already slightly carbonized board below it couldn't. It arced over, and I suddenly had a very nicely huge current flowing through my secondary. Power, of course, remained equal, and the current shot up through the primary as well. That got the transistors nice and toasty, and one of them just stuck on. When the transistor stuck on, it also fed decent amounts of power into the bases of the other two attached boards, and cooked the transistors on those as well. As far as I know, the transformers are still good.
Your turn...
[e: fixed image size. darn, 400px width is teeny!]
Registered Member #63
I've had several spectacular failures, some off the mains, some off my banks of seriesed lead-acid batteries (a bad habit, I admit).
Generally if a project of mine fails when connected to SLAs (36-48VDC), there is pink, red, blue, grey, or black smoke and a bad smell.
If it's connected to the mains, there is blasting around failed components, the most wonderful 50Hz "BVVVT, SPLATTER SPLATTER, FZZZZ" etc, by which time I'm yanking in vain at my variac's extension cord.
Here's a pictorial exploration I drew a while ago:
Registered Member #78
I've had a full bridge burst into orange flames on me once which working on my induction heater. and btw blackplasma, i think the smoke which comes out of semiconductors is poisonous, especially the colourful ones which you describe
Registered Member #89
All smoke is poisonous...
Well recently I pulled an arc with my finger from miniature SSTC (1,8cm dia) from middle of secondary, blew a hole in it and my finger smoked as well...
I had lots of explosions when working on small SMPS supply, blew couple of mosfets and bipolar transistors, and when they fail short 400V 100uF capacitor discharges violently trough them, later I put resistors and inductors to minimize current but they didnt help a lot...
Transistors are trashed and only few are kept to show, didnt want to bother of taking pics of two blown transistors...
Registered Member #50
I had a tesla coil strike to a power bar I had onboard and it caused a steady arc along with red/orange fire, 10 foot streams of vaporizing something, tons of scraping, burning and popping noises and melted 3 powerbar inlets.....
