  • Guests: 32
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Universal Driver 2.7 Rev C
first  3 4 5 6
Hydron
Thu Jul 07 2016, 07:55AM
Justin wrote ...
So I found out the hard way that if the UVLO pot (R29) is turned too far in the wrong direction(like say if you soldered it in that way) it feeds up to 16.4V into the LM8365 and kills it.
I'd suggest a 13k (E24) or better yet, a 13.3k (E48) resistor in series with the pot in the next revision to eliminate this issue - with 24Vin this should keep the ULVO input just below the absolute max of 6.5V even with the pot at 0 ohms.
DerStrom8
Thu Jul 21 2016, 04:09PM
DerStrom8 Registered Member #3704 Joined: Sun Feb 20 2011, 01:13PM
Hi loneoceans, I have just a couple of comments (corrections) to your schematic:
1) Your 7809 regulator does not seem to be annotated properly in the Rev C schematic? It's labeled "ICx" (Link2
2) The output from your UVLO chip is correct (it's labeled "To IC6A Pin 1 (CLR) via Jumper") but the corresponding comment on IC6A says "To OCD (IC11) Pin 1". This should read "To UVLO (IC11) Pin 1".
Regards,
Matt
loneoceans
Sat Aug 06 2016, 09:59PM
DerStrom8 wrote ...
Regards,
Matt
Thanks everyone for helping to point out the errors in the documentation and for the suggestions! Will be updating the pages etc. For the trimmer resistor, thanks for pointing that out! Typically though this isn't a problem since the trimmer pot comes set at its default value directly from the manufacturer in a good range for soldering directly and adjusting, but definitely something to take note of!
As a side note, for those interested, I have a bunch of UD2.7C PCBs in stock for $10/board or $25 for 3. See here: Link2
25262087975 Aab71d9eb1 N
Finally, I also just assembled a new bunch of my MIDI 2 controllers due to very popular demand: Link2 available if anyone is interested.
Nestade
Tue Jul 18 2017, 06:18PM
Nestade Registered Member #61642 Joined: Fri Jun 09 2017, 06:59AM
Hi,
Does anyone have a updated version of the mouser project (Link2 as some things are not available anymore and some aren't available before 2018.
However I'm not very experienced yet and I don't want to replace the parts with incompatible ones which may cause problems with the driver.
Regards,
Nestade
EDIT: Just replaced the missing compounds - will it work with this parts?
Replaced:
863-74HC08DR2G >> 863-MC74HC08ADR2G
71-CRCW0805-470-E3 >> 71-CRCW0805470RFKEB
71-CRCW0805-1.0K-E3 >> 71-CRCW0805-1.0K
71-CRCW0805-4.7K-E3 >> 71-CRCW0805-4.7-E3
81-GRM31CR71H475KA2L >> 80-C1206C475K5R
810-C3225X7R1H225K >> 810-C3225X7R1H225K-9
71-CRCW080510K0FKEB >> 71-CRCW0805-10K
71-CRCW0805-100K-E3 >> 71-CRCW0805-100K
71-CRCW121015R0JNEAH >> 71-CRCW121015R0FKEAH
652-TC33X-2-503E >> 652-TC42X-2-503E
nzoomed
Wed Jul 19 2017, 12:46AM
I think somewhere i posted a revised order list as there were a few things I found missing at the time that I build my coil also.
Ill try and find it.
Nestade
Wed Jul 19 2017, 10:46PM
nzoomed wrote ...
Hi,
Okay - thanks :)
Do you think my changes will work? (I listed the things I changed as this parts weren't available at the moment - would be nice if you could have a look if you have time as I'm a noob yet)
Regrads,
Nestade
first  3 4 5 6
